how to check amp for blown fuse(s)
Posted: Fri Jan 19, 2007 12:10 am
by vanman1
Changed my cd player with another factory unit. still no sound. Changed fuses at firewall for amp and for gauges fuse underneath dash. still no sound. Can you advise how to remove amp under the seat? how/where do you check the amp's fuses? I could pay someone but I want to learn how my Vibe works . Thanks to all responders. Dave
Re: how to check amp for blown fuse(s) (vanman1)
Posted: Fri Jan 19, 2007 9:03 pm
by kevera
Hey Vanman.I saw your other post and was wondering,from what vehicle was the radio you replaced the original with.Was it from another vibe,matrix,or other gm model.
Posted: Fri Jan 19, 2007 10:23 pm
Amplifier has NO fuses, breakers, or other resettable devices on it. Removing it won't help you.I would recommend a dealer visit at this point...might be a wiring issue...
Posted: Sun Jan 21, 2007 11:52 pm
by silvrhawk7
Almost sounds like it could be one of those stereos that need to be interfaced with the engines computer. Does the Radio itself give any messages or codes??
Re: how to check amp for blown fuse(s) (silvrhawk7)
Posted: Mon Jan 22, 2007 2:23 am
by mcgusto82
isn't the fuse labeled "cig" the radio fuse? Check that ifyou are getting no absolute power.
