Are 1ZZ & 2ZZ Water Pump Pulley's the same?
Posted: Thu Jan 18, 2007 2:45 am
by BlueCrush
Can any of you part number savant's see if the part number is the same for the 1zz & 2zz water pump pulley or know if they are the same?Thanks!
Re: Are 1ZZ & 2ZZ Water Pump Pulley's the same? (BlueCrush)
Posted: Thu Jan 18, 2007 3:46 am
by kevera
From what I found there is a difference between the 1z and 2z.The only # I found was for the gt,xrs and celica gt-s which is the same.#16173-88600,It's a toyota #,check here athttp://
www.Partznet.com.
Re: Are 1ZZ & 2ZZ Water Pump Pulley's the same? (kevera)
Posted: Thu Jan 18, 2007 3:51 am
by BlueCrush
Yeah, the info I found was there was a part number for the 2ZZ water pump pulley but all I found for the 1ZZ is that it's serviced with the water pump assembly. I was hoping someone could comfirm whether the pulleys were the same or not.
Posted: Thu Jan 18, 2007 3:53 am
by kevera
I would say they are different.
Posted: Thu Jan 18, 2007 5:44 am
by tnpartsguy
Pully isn't serviced on the 1zz, so I can't tell you for 100% sure. I'd bet not.
