				Video image inverted, how to fix it???
				Posted: Tue Jan 16, 2007 11:11 pm
				by Sub-Vibe-R
				I downloaded a video (an AVI file) and the image is inverted. Not only upside down but also it is like in a mirror. The writing are from right to left...Is there anything I can do to get this video the right way?
				Re: Video image inverted, how to fix it??? (Sub-Vibe-R)
				Posted: Tue Jan 16, 2007 11:15 pm
				by BlueCrush
				Wierd! That would be good to know.
				Posted: Tue Jan 16, 2007 11:18 pm
				by RePo
				There's nothing you can do to change it. It was encoded that way, and would have to be fixed by the owner that created it and then encoded again.  If you had the proper video editing software you could modify the avi, but the software is expensive and won't typically be found on an end user computer.  Try asking the person who created it why he did it.
				Re: Video image inverted, how to fix it??? (RePo)
				Posted: Wed Jan 17, 2007 12:12 am
				by Vibr8tr
				Is that an option on the windows movie maker? I use showbiz video and Sony Vegas.... but I know that I can use  some tools in there to change it.EDIT - There is a feature on windows movie maker that can mirror and rotate it 180 (basically flip it). I don't know if it will take your AVI file, but I put one in and flipped it.... worth a try.... maybe....
				Re: Video image inverted, how to fix it??? (Vibr8tr)
				Posted: Wed Jan 17, 2007 12:30 am
				by redlava
				Turn your monitor upside down and watch it in a mirror.  Sorry couldn't resist.
				Re: Video image inverted, how to fix it??? (redlava)
				Posted: Wed Jan 17, 2007 8:08 pm
				by MRCN RCE
				Quote, originally posted by redlava »Turn your monitor upside down and watch it in a mirror.  Sorry couldn't resist.lol thas what i was thinkin as i was readin the posts. good one
				Posted: Thu Jan 18, 2007 3:30 am
				by Sub-Vibe-R
				I will try this... I hope I have Windows Movie Make at home...At worst I have it at work.
				Posted: Thu Jan 18, 2007 5:34 am
				by Vibr8tr
				It should be standard with both Proffessional and Home. I can't promise what kind of output file there will be, or the quality, but it's a free way to do what you need.
				Posted: Thu Jan 18, 2007 4:07 pm
				by MRCN RCE
				Quote, originally posted by Vibr8tr »It should be standard with both Proffessional and Home. I can't promise what kind of output file there will be, or the quality, but it's a free way to do what you need.it's also a good idea to make a copy of the file before you try anything on it just in case somethin bad happens
				Re: Video image inverted, how to fix it??? (MRCN RCE)
				Posted: Thu Jan 18, 2007 8:53 pm
				by Vibr8tr
				Good advice right there. I don't know what the video is, but if it's something hard to get back, then....
				Posted: Thu Jan 18, 2007 11:18 pm
				by Sub-Vibe-R
				I made a quick test with Windows Movie Makers with a small .AVI file. It works fine.But I have another trouble. The file to be converted is 800Mb.Windows Movie Maker is not in the same PC. I tried to install it in the other one, it looks ok but when I try to load the AVI file, the software tells me the codec is missing, to enable the codec download.I check the option, re-loaded the file, same thing, but it tells me if I already downloaded the codec, to restart the application.I did it, and the message come over and over again....
				Posted: Sun Jan 21, 2007 4:51 am
				by Sub-Vibe-R
				Finally I found out what wrong...The video is not inverted.... It play well in Wondows Media player. It does not only in WinAmp
