Need to change Cat. converter anyone change theres yet?
Posted: Mon Jan 15, 2007 5:39 am
by high revin
Sent my car in today for it's 100k check up and it through a code a day after i set up apointment got my antifreeze, trany fluid etc changed plugs too and found out that i need a cat converter is why the car trough a codeQuestion is has anyone changed theres and if so which did you choose im going to run a high flow converter just wasnt sure if anyone else experinced any problem if they used a high flow cat?
Re: Need to change Cat. converter anyone change theres yet? (high revin)
Posted: Mon Jan 15, 2007 6:04 am
by BlueCrush
Hey George, I had mine switched to a Magnaflow high flow cat (don't know part # though) about 1-1/2 yrs. ago w/no problems at all since. I had it replaced when I had my custom exhaust done.
Posted: Mon Jan 15, 2007 11:11 am
by high revin
Cool thanks how much did it run you by the way and were did you get it?
Re: (high revin)
Posted: Mon Jan 15, 2007 11:14 am
by BlueCrush
The cat itself was $50 or $60 I believe and the local performance exhaust shop that did my exhaust work had it in stock.
Re: (BlueCrush)
Posted: Tue Jan 16, 2007 8:27 am
by high revin
cool thanks dude
