%&@# Oil Filter!
Posted: Sun Jan 07, 2007 9:53 am
by NewNeptune
I went to change my oil today and I could not remove the oil filter. It wouldn't budge by hand or with a wrench. Stupid monkeys at the dealership either put it on way too tight or didn't put any oil on the ring. It's got an AC Delco filter which is smooth and almost completely round, so nothing to really grip on to.Any suggestions for getting it off next time?
Re: %&@# Oil Filter! (NewNeptune)
Posted: Sun Jan 07, 2007 9:57 am
by JohnC
I use a plastic socket that fits the indentations on the very bottom of the filter. Are you saying that the Delco filter doesn't have these?
Re: %&@# Oil Filter! (JohnC)
Posted: Sun Jan 07, 2007 10:21 am
by NewNeptune
The ones it has are very slight. It is almost smooth all the way around. The plastic cap that I have bends before I can apply enough force to move the filter.
Posted: Sun Jan 07, 2007 10:38 am
by jwalcik
it's not the cleanest, or most fun way to do it, but i got one off of a friends old nissan once by stabbing a screwdriver all the way through the filter to make a handle.
Posted: Sun Jan 07, 2007 11:00 am
by cmhj2000
Had a similar issue with mine. Ended up using a large channel locks to get it broke loose.
Posted: Sun Jan 07, 2007 11:15 am
by goodvibe
I'D MAKE THE DEALER DO IT FOR FREE. BRING YOUR OIL AND FILTER.
Posted: Sun Jan 07, 2007 11:22 am
by NewNeptune
The dealer is an interesting option. They have this policy where if they don't look at all the lights, fluids etc. when you check it in, they will give you a free oil change. They've never done that for me.With the oil filter located where it is and my big hands, I don't see any way where I could get a screwdriver into it.
Posted: Sun Jan 07, 2007 11:29 am
by Ol' Timer
Quote, originally posted by NewNeptune »I went to change my oil today and I could not remove the oil filter. It wouldn't budge by hand or with a wrench. Stupid monkeys at the dealership either put it on way too tight or didn't put any oil on the ring. It's got an AC Delco filter which is smooth and almost completely round, so nothing to really grip on to.Any suggestions for getting it off next time?Man, do I hate to hear this one. I've have heard about this 300lb Gorilla tightens them up at the factory so I had the Stealership do my first oil change. I told them that I wanted the secretary to hand tighten the filter after they wrench the old one off. Well, I guess they had Big Bad Bertha install the new filter, 'cause the replacement filter was NOT what I would call "Hand Tightened". I used a metal oil cup that fit on the Delco Filter to finally get the filter off. I have never had a problem getting the filters off since I've been hand tightening the filters myself.
Re: %&@# Oil Filter! (Ol' Timer)
Posted: Sun Jan 07, 2007 12:38 pm
by Digger
I have done the stab and twist before. I looked good covered in black used oil. Go to the parts store and tell them you need a filter wrench to fit yours. I would say a metal end cap, chain or strap filter wrench would work best. The best one I got is a "U" type clamping wrench that squeezes the filter. Bad thing is it did not fit ours. not sure if they make that time as small as we need.
Posted: Mon Jan 08, 2007 6:05 am
by mathteacher'04vibe
Is there room to get a punch in there? I was working on a Ford van that had King Kong at Wal Mart put the filter on. I tried an air hammer with a punch--that was not enough. The screwdriver and a filter wrenches (nylon strap and metal U) ended up making the filter look like a pretzel. Last resort was a handheld sledge hammer and a punch at the base of the filter. I haven't changed my oil yet (2400 miles since last change and waiting to hit 45k), but I will get my punch ready for when I do.
Re: %&@# Oil Filter! (mathteacher'04vibe)
Posted: Mon Jan 08, 2007 6:49 am
by frank@toronto
This was my solution:Use one of those oil filter remover plastic caps (the ones that never really fit your filter). Pre drill two holes (see picture below).Place cap over oil filter and "jab" two screws into it.Unscrew cap using square head ratchet.
Re: %&@# Oil Filter! (frank@toronto)
Posted: Mon Jan 08, 2007 6:59 am
by KNINE
That's a good idea! My original filter was a bear to get off. I used a large set of channel locks. I pretty much crushed the filter, but it came off.
Posted: Mon Jan 08, 2007 9:27 am
by PhantomMatrix
i had the same problem with the toyota OEM filter the dealership put on, i ended up using the above picture end cap 65mm (smallest one on the rack) and an extention on the ratchet. that finally did it, i never thought of using screws, it's really messy down there.
Posted: Tue Jan 09, 2007 2:34 am
by MNMSGALL
Same problem here too. I ended up taking off the rock guard to get more room to play with, and more leverage, and slipping a strip of rubber inbetween my filter and my wrench to get more grip on the filter. After that, it came right off.
Posted: Wed Jan 10, 2007 2:18 pm
by NewNeptune
I might try the screw trick. What are the chances that it will mutilate the filter instead of taking it off?
