audio?
Posted: Thu Jan 04, 2007 3:32 am
by coldmm803
i just got a creative zen mp3 player and want to be able to use it in my vibe. i did some searching and see that i can use an aux converter or get a new HU.i'm leaning more towards the new HU with an aux on it. i know absolutly nothing about audio parts so what do i need to know. i'll most likely buy thru crutchfield. i have an 05 with M&T.having gone thru some threads i see this mounting bracket, will the HU come with that? and what about harnesses?thanks in advance
Posted: Thu Jan 04, 2007 5:13 am
by ragingfish
crutchfield gives you the wiring harness, the antenna adapters, and the dash kit. if you get a unit from them, you shouldn't need anything else.
Re: audio? (coldmm803)
Posted: Thu Jan 04, 2007 8:14 am
by GMJAP
Since you have M&T, you have the factory amp, which complicates it a little bit. Be sure Crutchfield understands this if you order from them.You may need a line level converter between the new head unit and the factory amp to get rid of noise that often occurs hooking up an aftermarket HU to the factory amp. Search on "line level" in message bodies and you should find a lot on it.It's not recommend to chuck the factory amp, as the factory speakers for the M&Ts are 2 Ohm, and aftermarket HU are not made to drive anything less than 4 Ohms.
Re: audio? (GMJAP)
Posted: Sat Jan 06, 2007 12:15 am
by coldmm803
replacing the HU appears to be costing more that i can afford so i'm gone go with the PIE GM12-AUX. $70 vs $150+ i'll go with the 70thanks for your help guys
Posted: Wed Jan 10, 2007 10:03 am
by coldmm803
when i install the aux box do i need to worrry about the "anti theft" with the M&T package or is the red led just for show?thanks
Posted: Wed Jan 10, 2007 11:21 am
by GMJAP
The LED is just for show. There is no difference between the head units with or without M&T, and they don't have theftlock. If you had factory XM I've heard it might be a problem, but I've removed both a stock 6CD and several 1CDs and never had lock issue.
Re: audio? (GMJAP)
Posted: Sat Jan 13, 2007 6:57 am
by coldmm803
i installed the PIE GM12-AUXV2 today and it was pretty easy to do and is workin great. as others have stated in various threads, you do need to turn up the volume more but theres plenty of sound to pump out with the M&T package. i have no hiss. i have to use the band button to switch to the aux for it. i routed my RCA to headphone cable down into the bottom storage compartment.
Posted: Sat Jan 13, 2007 8:29 am
by keithvibe
where are the photos
