Does anyone know the stock speaker wattage?
Posted: Mon Jan 01, 2007 1:55 am
by SalsaVibe2003
I just installed a new Alpine head unit in my 03 Vibe. Everything is working, save the popping noise that is heard whenever i change tracks and the fact that the volume at 5 is the loudest i would go. I know that line level converters would solve the second issue, but i was toying with the idea of an aftermarket amplifier. So i was wondering if anyone knew the wattage of the stock speakers, in case there was any possibility that i could get away without replacing them. Thanks guys!
Posted: Mon Jan 01, 2007 8:52 am
by Jahntassa
If you aren't using the M&T system, probably RMS of around 12 watts, maybe peak of 23w.If you're using the M&T system, I have no idea, but you'd need to get an amplifier capable of driving six speakers at 2 Ohms. The tweeters have a crossover built into the factory amp. (Or you'd need a four channel with crossovers for the tweeters).The stock speakers on M&T are probably around 23w RMS @ 2 Ohms, guessing 50w Peak.This is all assumption though.
Posted: Tue Jan 02, 2007 10:11 am
by SalsaVibe2003
Re: Does anyone know the stock speaker wattage? (SalsaVibe2003)
Posted: Tue Jan 02, 2007 11:19 am
Posted: Sun Dec 30, 2007 1:10 am
by briantforce
I just changed out the speakers in my 2003 gt wtih the 4 speaker system and the stock were 17.5w peak
Posted: Tue Jan 01, 2008 10:01 pm
by Sublimewind
Yeah, without knowing what stock system you have it's hard to say... If you are using the factory amped system, it's best to bypass when changing things... If it's a non-amped system, then there shouldn't be an issue...
Re: (Sublimewind)
Posted: Tue Jan 01, 2008 10:05 pm
by Raven
Wow a 1 year timewarp response time.
