changing out the internal overhead reading lamp
Posted: Wed Dec 27, 2006 2:10 am
by dereknicholas
Hi, I am a new member and really appreciate this board.Does anyone out there have any info on changing out the internal reading lamp on the moon and tunes model?
Re: changing out the internal overhead reading lamp (dereknicholas)
Posted: Wed Dec 27, 2006 3:46 am
by Mrizzle05
This should be posted in the interior section.But since your new to the site well give you a pass!!Im from T.O. aswell... what color is your vibe?Where abouts are you? im off Lynn Rd. Check the socal forum for local meets
Posted: Wed Dec 27, 2006 4:51 am
welcome to genvibeQuote, originally posted by dereknicholas »Does anyone out there have any info on changing out the internal reading lamp on the moon and tunes model?If you mean how to replace a burned out map light bulb in the moonroof control assembly, then first remove the one screw that you see in the cover. Then, roll your fingertips under the cover and pull it off. The whole plastic cover, gray and clear, comes off as one piece. From there it should be easy enough to swap the bulb.http://forums.genvibe.com/zerothread?id=12225 is an index of interior light bulbs, which says that that bulb is a "1895", looks like a bayonet type, 1/4 turn to put in/take out
