Toyota T-F (T-IV) transmission fluid (auto-base)???
Posted: Sat Dec 23, 2006 2:40 am
by bagwell
I read thru 20 different tranny fluid threads and wanted clarification this is the correct fluid to use.Thanks!
Re: Toyota T-F (T-IV) transmission fluid (auto-base)??? (bagwell)
Posted: Sun Dec 24, 2006 11:09 pm
by 2002sportside
Manual calls for T-IV fluid only.
Posted: Sun Jan 07, 2007 10:43 am
by PhantomMatrix
yes T-IV, i just use amsoil, since it's a synthetic and it's compatible.
Posted: Thu Jan 18, 2007 3:33 pm
by ShannanCa
make sure you get the tranny fluid from the Toyota dealership and NOT from Pontiac. I paid like $4 or $6 a quart or something from Toyota and Pontiac wanted $14 a quart! Same fluid! Reasoning from Pontiac is that the Vibe is the only Pontiac vehicle with this Toyota transmission. Type T-IV.
Posted: Thu Jan 18, 2007 10:22 pm
by goodvibe
Use the recommended fluid. Toyota or GM. I wouldn't use the Amsoil. Their 'compatible with' disclaimer doesn't involve any certified testing in the application. There's no universal ATF now a days. Mobil 1 for instance specifically says not to use their universal synth ATF in this app. Different tranny's need different friction levels and viscosity's to work properly. ATF isn't filtered and tranny operation produces lots of insolubles from pad wear. Acid neutralization also wears out over time so you're better off with more frequent changes and don't need synth. The pads and bands need a very specific set of conditions to work properly and less friction would be a bad thing for instance. Amsoil may or may not be optimum for this tranny but there's no way to tell from their specs and seat of the pants can be misleading. Either firmer or smoother shifting than stock could be a bad thing for longevity. Same for additives. You don't want to change the character of the stock fluid that the tranny was designed with. It's an integral part of it's correct operation and not like motor oil where less friction is always good and a wide range of visc. work fine.
Posted: Fri Nov 19, 2010 12:12 pm
by gumbeaux1979
I like the Royal Purple Fluid.
Re: Toyota T-F (gumbeaux1979)
Posted: Mon Nov 22, 2010 11:09 am
by zionzr2
Quote, originally posted by gumbeaux1979 »I like the Royal Purple Fluid.Running Royal Purple fluids in mine!
Re: Toyota T-F (zionzr2)
Posted: Mon Nov 22, 2010 8:38 pm
by KNINE
Is it really purple?
Posted: Mon Nov 22, 2010 10:59 pm
by lovemyraffe
T-IV
Re: Toyota T-F (K-NINE)
Posted: Tue Nov 23, 2010 1:38 am
by Wolfman213
Quote, originally posted by K-NINE »Is it really purple?Not sure about the trans fluid, but IIRC the oil is.
Posted: Tue Nov 23, 2010 8:48 am
by zionzr2
yes it really is purple but it does not stay purpleafter a trip or two it turns the normal color for the fluid
Posted: Thu Dec 27, 2012 12:13 am
by daniel4888
will castrol work?
Re:
Posted: Fri Dec 28, 2012 6:24 pm
by CharlesinGA
goodvibe wrote:Use the recommended fluid. Toyota or GM. I wouldn't use the Amsoil. Their 'compatible with' disclaimer doesn't involve any certified testing in the application. There's no universal ATF now a days. Mobil 1 for instance specifically says not to use their universal synth ATF in this app. Different tranny's need different friction levels and viscosity's to work properly. ATF isn't filtered and tranny operation produces lots of insolubles from pad wear. Acid neutralization also wears out over time so you're better off with more frequent changes and don't need synth. The pads and bands need a very specific set of conditions to work properly and less friction would be a bad thing for instance. Amsoil may or may not be optimum for this tranny but there's no way to tell from their specs and seat of the pants can be misleading. Either firmer or smoother shifting than stock could be a bad thing for longevity. Same for additives. You don't want to change the character of the stock fluid that the tranny was designed with. It's an integral part of it's correct operation and not like motor oil where less friction is always good and a wide range of visc. work fine.
I use Amsoil in my '04 model. I dump and refill (about three qts) every 10,000 mi oil change, its been done a total of 5 times so far, first three right after 50,000 when I bought the car, about a week apart, and then at 60K and at 70K. It works just fine, cannot tell a difference.
Its not like Toyota makes this fluid themselves, someone makes it for them. Amsoil has testing labs and enough knowledge to know if the fluid is compatible/safe to use in it.
You could say the same thing about About any car, that Amsoil is not the correct fluid and might cause problems, thus what you are really saying is that no one should ever use anything but the fluid sold by the dealer for that car, no matter what kind of car it is.
Charles
Posted: Tue May 17, 2016 3:59 pm
by Chiadog
Bump, Castrol Transmax Fully Synthetic Multi-Vehicle looks compatible with toyota T-4 .
Exceeds requirements of JASO-1A and recommended for a wide range of import vehicles.
This includes Toyota/Lexus according to the spec. sheet pdf, Which can be downloaded (bottom link) from Castrol website: upper link is to the MSDS.
http://msdspds.castrol.com/msdspds/msds ... =No&cols=0
