left my roof popped up and it rained med hard all day....
Posted: Fri Dec 22, 2006 12:51 pm
by bagwell
no water on the seats....but when I made a right turn, water dripped down (streamed in) from the front upper left roof where the headliner meets the plastic piece by the windshield. Has anyone had this happen? did water get inside the body of the car???
Posted: Fri Dec 22, 2006 12:53 pm
if you mean it came from the a-pillar...one of the roof drains goes through there, so it could be clogged. otherwise, i can't see your seats being dry but the inner body being soaked.
Re: left my roof popped up and it rained med hard all day.... (bagwell)
Posted: Fri Dec 22, 2006 12:58 pm
by CAN-AWD-VIBE
Quote, originally posted by bagwell »no water on the seats....but when I made a right turn, water dripped down (streamed in) from the front upper left roof where the headliner meets the plastic piece by the windshield. Has anyone had this happen? did water get inside the body of the car???i guess the water would follow the sunroof molding down inside the roof... check your dome light and roof switch for water! Even if a little water gets on there you will be fine, i have made that mistake before, wide open, with hail. That was fun.
Re: left my roof popped up and it rained med hard all day.... (CAN-AWD-VIBE)
Posted: Fri Dec 22, 2006 9:51 pm
by mcgusto82
once i left the sunroof open and it rained. My seats were also dry, but my carpet was dripping wet. So, check that.if it is, you gotta pull out both front seats, t pull up he carpet and dry it. Otherwise. it's goin to be one musky vibe.
Re: (ragingfish)
Posted: Sat Dec 23, 2006 1:58 am
by bagwell
Quote, originally posted by ragingfish »if you mean it came from the a-pillar...one of the roof drains goes through there, so it could be clogged. otherwise, i can't see your seats being dry but the inner body being soaked.so how do you unclog the roof drain(s)...where are they located?
