Bad Catalytic Convertor?
Posted: Thu Dec 14, 2006 2:12 pm
by Petrucci914
Hello,Lately when I take off from a stop I hear a clanking sound underneath. This started a few months after I installed my DC Sports Header. I was thinking there was a loose bolt but I doesn't seem that way (I'll check it soon). Lately it seems like it shifts a little crappier especially at low RPMs and low gears and my gas mileage has never been that great........... do you think maybe a bad catalytic convertor? I knew someone that thought their transmission was bad but their cat was so clogged and he couldn't move at all. Any thoughts on this? I can get a Magnaflow hi-flow cat for 55$ so I plan on buying one anyways........... thanks.
Posted: Fri Dec 15, 2006 10:46 am
by CAN-AWD-VIBE
then who cares... just buy the high flow and if the noise and your power problems are gone, bonus.if not then let us know
Re: (CAN-AWD-VIBE)
Posted: Fri Dec 15, 2006 10:49 am
by Petrucci914
Your thinking is the reason my credit card bill is higher than my savings account, lol........... oh well, I still like that thinking.
Re: (Petrucci914)
Posted: Fri Dec 15, 2006 11:03 am
by CAN-AWD-VIBE
lol I had to put out two cards with a fire extinguisher after my wife got back from the mall today... i dont mind that kind of thinking seriously, you might have a cat problem or you might have loose bolts or a heat shield? But if you plan on replacing the cat with the high flow anyway, then get it, eliminate it as a suspect and pick up a better flowing exhaust while your at it.it is also my specialty to talk myself (or you in this case) into doing this kind of stuff, its way more fun this way I promise. I am not the best with saving money but I can sure spend it.
Re: Bad Catalytic Convertor? (Petrucci914)
Posted: Sat Dec 16, 2006 1:44 am
post up some info on that $55 cat, I had to replace mine and it was over $500, a daler only part. Is that a special deal just for you, or ithat an everyone price?
Posted: Sat Dec 16, 2006 3:39 am
by CAN-AWD-VIBE
you can get the magnaflows on ebay or whatever for about $50-$70universal fit, so a trip to the shop is required, but install cost and results are worth it. IMHO. Better then the $500 touch at the dealer for the same old restrictive, clogging up too fast OEM cat.
Posted: Sat Dec 16, 2006 5:07 am
by Lancer
When my pre-cat blew out and emptied into the main cat, it had a deffinate rattle (from all the chunks of the core) and like you said, it takes off from a stop really slow and just seems like it was loosing power. Give the cat a good rap with you knuckles. If you hear the rattle, you got your answer.I got mine off a e-bay store for $36. After I bought that one, I found another with the O2 sensor bung for $30. It's a highflow, metal core, 2 1/2" in/out. It's a little smaller than the magnaflow one cause it doesn't have the heat shield. Too bad the idiot that istalled it, tore into my borla piping and put it just before the borla muffler. But it shouldn't cost much at all to have it installed. Maybe $50 at the most.
Re: Bad Catalytic Convertor? (Lancer)
Posted: Sat Dec 16, 2006 2:18 pm
by Petrucci914
Ebay has the Magnaflow for 55$. You'll have to pay to have it welded on and such, of course.
Posted: Mon Dec 18, 2006 1:08 am
by Petrucci914
Which of these would work better? Do you think I need to spun one in order for it to feet nicely? I think the other universal one may be too big. Give me your thoughts. Thanks.
http://cgi.ebay.com/ebaymotors...58746h ... s...58759I don't need one with a bung, correct?
