Any '06's with the rotten egg (bad Cat Converter) smell?
Posted: Thu Nov 23, 2006 10:30 pm
by tnpartsguy
Mine now has about 3K miles on it, and it's 10 times worse than the '03 ever got....you can smell this thing from the front porch (35 feet + away). Of course the bulletin only goes to 05's, but the '06's have the same old part # converter as the '03~05's.
Re: Any '06's with the rotten egg (bad Cat Converter) smell? (tnpartsguy)
Posted: Fri Nov 24, 2006 8:41 am
by VforVIBE
Is the car warmed up when you get the smell or is it cold?
Posted: Fri Nov 24, 2006 9:05 am
by ColonelPanic
That sucks, man! Problems already! If it is that bad, whether a TSB applies or not, they need to do something about it...
Posted: Fri Nov 24, 2006 9:57 am
by Ol' Timer
Quote, originally posted by tnpartsguy »Mine now has about 3K miles on it, and it's 10 times worse than the '03 ever got....you can smell this thing from the front porch (35 feet + away). Of course the bulletin only goes to 05's, but the '06's have the same old part # converter as the '03~05's.Have you tried different brands of gasoline?
