cleaning up and painting rear drum brakes with disk brakes on an '03 vibe
Posted: Sat Nov 11, 2006 9:47 am
by sagekai
My Vibe is an '03 Automatic and I'm really not into the look of the drum brakes... whats the best way to go about getting the drums replaced with disk brakes? Thanks!
Re: replacing rear drum brakes with disk brakes on an '03 vibe (sagekai)
Posted: Sat Nov 11, 2006 9:49 am
by scherry2
buy a GT.no really.the cost wouldn't be worth it. even using used parts.
Posted: Sat Nov 11, 2006 10:00 am
by sagekai
In that case, since I spend alot of time at the beach, the outsides of my drums are pretty rusty from all the salt, water, etc. Whats the best way to clean them up, paint them and protect them?
Posted: Sat Nov 11, 2006 1:11 pm
by CAN-AWD-VIBE
maybe get them powdercoated?
Re: (CAN-AWD-VIBE)
Posted: Sat Nov 11, 2006 9:17 pm
by scherry2
Quote, originally posted by CAN-AWD-VIBE »maybe get them powdercoated?that would be the best way. any color you like too.
Posted: Sun Nov 12, 2006 2:03 am
by sagekai
sorry for my ignorance here, but is the powdercoating something i would do myself with a kit, if so where is a good place to buy it at?, or something i would get professionaly done?
Re: (sagekai)
Posted: Sun Nov 12, 2006 3:42 am
by scherry2
look in the yellow pages for "powdercoating" I had my roof rails done not once but twice for $10.00 per rail each each time.http://en.wikipedia.org/wiki/Powder_coatingif you have a spare oven and a small kit I guess you could do it. I've been checking systems (home not industrial size) out.here are some spots out there I got from yellowbook.comhttp://www.yellowbook.com/?T=1...2&y=9
Re: cleaning up and painting rear drum brakes with disk brakes on an '03 vibe (sagekai)
Posted: Sun Nov 12, 2006 4:55 am
by djb383
If you pull off your drums and sand the outsides well, a spray can of Rustoleum paint should last a good while and only cost $3-$5, plus elbow grease. Be sure to clean the working sides well before replacing and post some pics.
Posted: Sun Nov 12, 2006 1:12 pm
by sagekai
I just finished spraying the first drum with the silver Rustoleum finish paint and I'm really stoked with how it looks. The paint ran a little, but its hardly noticeable. Going to start the next one in about an hour. Thanks for all the help!
Re: (sagekai)
Posted: Sun Nov 12, 2006 1:19 pm
by joholste
if you really want to change over then check out stainless steel brake corporationhttp://www.stainlesssteelbrakes.com/$795.00 with a minimum wheel size of 17"the nice thing about these is you wouldn't need to worry about rust with the stainless steel
Re: (joholste)
Posted: Mon Nov 13, 2006 1:58 am
by SeattleJeremy
Check out this thread on changing Drums to disks. The process should be the same on a Vibe/Matrix.http://www.newcelica.org/forum...rsion
Re: (sagekai)
Posted: Mon Nov 13, 2006 9:53 am
by sagekai
alright djb, i went with you on this one and i'm stoked with how it turned out
Re: (sagekai)
Posted: Mon Nov 13, 2006 10:17 am
by djb383
Dude, looks great, and if you want to change color later on, just ruff'em up a little with sandpaper and try another color.
Re: (sagekai)
Posted: Mon Nov 13, 2006 11:23 am
by CAN-AWD-VIBE
that did turn out well... I might do mine black and was going to match the front calipers too.
Re: (CAN-AWD-VIBE)
Posted: Tue Nov 14, 2006 1:50 am
by damronjr
Been wanting to do mine forever, someday I will get out of my lazy stage and actually do these things! I've had the paint sitting in my car for well over a year now!
Re: (damronjr)
Posted: Tue Nov 14, 2006 1:53 am
by Mrizzle05
Looks good man... i did mine with dupli-color caliper paint. looks more textured, but black and better then that ugly rust color. and they still look good now. after washes and dirt.
