Rims on a 98 Accord
Posted: Sun Nov 05, 2006 10:10 am
by Vibe_dude
I have a 98 accord dx.......stock tires are on it......195/70/14 My ? is this......I just came into a brand new set of 02 civic si rims and tires...they are 185/65/15. They are both 4 bolts.......just wondering if the new rims will fit or not.......and if they do what size of tire should i run on these si rims? THX's
Re: Rims on a 98 Accord (Vibe_dude)
Posted: Sun Nov 05, 2006 10:16 am
by damronjr
First off, you have to know the bolt pattern (i.e. the bolt pattern for the Vibe is 5 lug x 100mm). The bolt pattern has to be the same for the rims to fit. Knowing they are both from a Honda is positive, but not guaranteed that they will be the same. Also, you need to make sure they both have the same rolling diameter or your speedo/odo could be thrown off by the wrong size. You also need to make sure the offest is the same as well! Lots of things to look at.
Re: Rims on a 98 Accord (damronjr)
Posted: Sun Nov 05, 2006 12:52 pm
by Viberrrr
From my chart it doesn't look like they will work.
Posted: Sun Nov 05, 2006 10:27 pm
by CAN-AWD-VIBE
looks like nomost of the time hondas are4x1005x114they did this stupid 4cyl gets 4 bolt and v6 gets 5 in 98 and up accordsthat chart sure comes in handy viberrr... mind if i ask where you got it?
Re: (CAN-AWD-VIBE)
Posted: Mon Nov 06, 2006 10:41 pm
by Viberrrr
I used this link with great success to find a set of steel rims for my snow tires. Because of this list I discovered I had 4 rims sitting in my garage that would work. Yeee Haaaw. Here is the link: http://www.sromagazine.com/shop/wheelguide.html
Posted: Tue Nov 07, 2006 3:11 am
by Vibe_dude
Well just for giggles i had time and went and tried them on the car.....and alas they did not fit.......it is a shame.those si rims i have are in prime shape....and would have looked good.........but i guess the are a official no go.....i guess i will have to sell them..maybe put them in the local paper.
