Can someone explain step by step how to change the cabin air filter?
mcstamper
Post by mcstamper »
Is this something the typical home mechanic could do? Thanks.
mspalmer
Re: Can someone explain step by step how to change the cabin air filter? (mcstamper)
Post by mspalmer »
It is pretty easy, I did mine about 2 weeks ago. You have to open your glove box and take out the screw on the right side of the open glove box that holds it open. Then pull out the glove box.After that pull off the plast cover that will be right in that newly opened space and the filter is right there. Gently remove because their may be a lot of dirt and dust accumulated on it. I know mine was pretty dirty after 18 months. Also you can see:http://forums.genvibe.com/zerothread?id=982for a picture or do a search for cabin filter.It is very easy and takes only a couple minutes.Mike
2005 Platinum AWDMoons and TunesXM RadioLLumar Window TintingWeathertech ventshauling my Taylor 410 w/Fishman pickup and Gibson SG guitars
NewNeptune
Post by NewNeptune »
Screw, what screw? I didn't need to remove no stinkin' screw!Honestly, did I break something by not removing the screw?
2006 Pontiac Vibe Base, Automatic, Power PackageSony CDX-GT300Upgraded Horns
Re: (NewNeptune)
Quote, originally posted by NewNeptune »Screw, what screw? I didn't need to remove no stinkin' screw!Honestly, did I break something by not removing the screw?There is a damper thing that keeps the glove box from flopping around when it's open, and it attaches to the right side of the glove box with one screw. The most straightforward thing is to remove that screw before you take the glove box off, but you can just reach in and pull the damper assembly off the post it attaches to in the dash, and leave it screwed on to the glove box. I usually do the latter, but have done the former.Not knowing what you did, can't say if you broke something or not.
ajflan
Re: (joatmon)
Post by ajflan »
This reminds me... I should probably put a new filter in mine. I've been running without it for 2 months now. I'll get it... After the Tein S-Techs.
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
NewNeptune
Quote, originally posted by joatmon »There is a damper thing that keeps the glove box from flopping around when it's open, and it attaches to the right side of the glove box with one screw. The most straightforward thing is to remove that screw before you take the glove box off, but you can just reach in and pull the damper assembly off the post it attaches to in the dash, and leave it screwed on to the glove box. I usually do the latter, but have done the former.Not knowing what you did, can't say if you broke something or not.Well, my glove box doesn't flop around when I open it, so that is a good sign. I think I ended up doing the latter method.
LUVROK
Post by LUVROK »
My 05 doesn't have a screw, or if it does I don't need to remove it. I haven't changed the cabing filter, only have 6,000 miles, but have sent many wires back there. I open the glove box, pull up and out on it, then pull the left side out, then tilt the assembly down and pull the back end of the damper at the right side of the glove box. The damper and glovebox are flexible enough to bend things to see what you are doing or feel what is going on behind the glove box.
2005 GT, Neptune, Injen CAI, Magnaflow Catback Exhaust, Eibach Sportline Springs, Progress Rear Swaybar, DC Sports Strut Tower Bar, Tow package
