04 Vibe Alarm Wiring Guide
Posted: Wed Oct 18, 2006 1:17 pm
Here is another wiring guide for the 04: from the12volt.comDIRECTWIREâ„¢ WIRING INFORMATION - PONTIAC / VIBE / 2004 / Remote Start[PRINT THIS PAGE]12volts white (25A) & black (15A) + ignition harnessStarter red + ignition harnessSecond Starter N/A Ignition black/white + ignition harnessSecond Ignition black/yellow + ignition harnessThird Ignition N/A Accessory blue/red + ignition harnessSecond Accessory N/A Keysense blue/black - ignition harnessNotes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.Power Lock green - driver kick, blue 12 pin plugNotes: Meter these wires while turning the key in the driver door key cylinder.Power Unlock blue/yellow - driver kick, blue 12 pin plugNotes: Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse.Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a blue 12 pin plug.Lock Motor blue 5wi driver kick, blue 12 pin plugUnlock Motor red 5wi driver kick, blue 12 pin plugParking Lights+ green + driver kick, harness to rearParking Lights- green/white - headlight switchHazards yellow/black - flasher relay left of fuse boxTurn Signal(L) green/black + flasher relay left of fuse boxTurn Signal(R) green/yellow + flasher relay left of fuse boxReverse Light red/black + front of fuse box, 10 pin plugDoor Trigger red/white - interior light switch on dashDome Supervision comes on with unlock Trunk/Hatch Pin common with door trigger Hood Pin N/A Trunk/Hatch Release blue/white - release switch on dashPower Sliding Door N/A Factory Alarm Arm arms with lock Factory Alarm Disarm disarms with unlock Disarm No Unlock use key sense wire Tachometer black ac pin 5, conn. E6 at ECMNotes: The ECM (Engine Control Module) is behind the glove box. Connector E6 is the plug on the right.Wait to start N/A Brake Wire green/white + brake pedal switchParking Brake red/black - parking brake switchHorn Trigger green/yellow - steering columnMemory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Immobilizer Bypass Module: Required: No Type: N/A Part #: N/ANotes: N/AwarningThis wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
