Check engine light (CAI)
Posted: Wed Oct 04, 2006 12:32 pm
by nuvibe
I installed a short ram on my ride and the check engine light came on a couple day's later, Help! Is this going to be an on going problem? or then I'll go back to stock...... nuvibe
Re: Check engine light (nuvibe)
Posted: Wed Oct 04, 2006 12:47 pm
by Petrucci914
Make sure you that unhooked the battery after you installed it to reset the ECU. Then let the car idle for 10 minutes. You also want to make sure everything is connected correctly and tightened. Be careful of the MAF sensor because it's easily damageable and you may want to clean it.
Posted: Wed Oct 04, 2006 12:53 pm
by nuvibe
Thank's for the info. Petrucci914; Should I reinstall the MAF again and go though the step by step.... nuvibe
Posted: Wed Oct 04, 2006 1:32 pm
by northvibe
yea take the negative off the battery for 10 min the plug back in. what SRI did you get? oiled filters can dirty the maf sensor and make it throw a CEL, you can try some MAF cleaner on the sensor.
Re: (northvibe)
Posted: Wed Oct 04, 2006 8:25 pm
by 2002sportside
Make sure the MAF is in the right way too. That will cause a CEL. Do you know what the code is?
Re: (2002sportside)
Posted: Wed Oct 04, 2006 11:41 pm
by goodvibe
If you used an oil gauze filter, you may want to clean the MAF also before you reset.
Posted: Thu Oct 05, 2006 2:36 pm
by nuvibe
Sorry for the late reply. MAF is clean so I'm going to double check every thing. Plus I called my brother and he helped me and went through some thing's with me to check also, he's a smog tech... nuvibe
