free TSBs for the 2004 Vibe
Posted: Tue Oct 03, 2006 10:25 pm
by bagwell
Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 030601020 Date of Bulletin: NOV 01, 2005 NHTSA Item Number: 10012558 Component: ENGINE AND ENGINE COOLING Summary: AVOIDING OIL BAFFLE DAMAGE DURING OIL FILL PROCESS. *EH Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040605011A Date of Bulletin: NOV 01, 2005 NHTSA Item Number: 10014960 Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM Summary: SULFUR (ROTTEN EGG) SMELL COMING FROM EXHAUST. *TT *JB Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 03082005 Date of Bulletin: MAR 08, 2005 NHTSA Item Number: 10014837 Component: FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK Summary: INACCURATE FUEL TANK PRESSURE SENSOR READING. *EH Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 701 Date of Bulletin: JAN 01, 2005 NHTSA Item Number: 10015762 Component: FUEL SYSTEM, OTHER Summary: FUEL FILTER REPLACEMENT. GM TECH LINK. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 611 Date of Bulletin: NOV 01, 2004 NHTSA Item Number: 10016257 Component: EXTERIOR LIGHTING:HEADLIGHTS Summary: AUTOMATIC HEADLAMP-OWNERS MAY COMMENT THAT THE AUTOMATIC HEADLAMP SYSTEM DOES NOT TURN THE HEADLAMPS ON WHEN THE VEHICLE IS STARTED DURING LOW LIGHT CONDITIONS. *SC Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 05062004 Date of Bulletin: MAY 06, 2004 NHTSA Item Number: 10013213 Component: EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL Summary: CIGARETTE LIGHTER HOUSING PULLING OUT OF THE DASH. *EH Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040849014 Date of Bulletin: MAY 01, 2004 NHTSA Item Number: 10008488 Component: STRUCTURE Summary: CIGAR LIGHTER HOUSING PULLS OUT OF DASH. *MJ Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01202004 Date of Bulletin: JAN 20, 2004 NHTSA Item Number: 10009095 Component: ELECTRICAL SYSTEM:STARTER ASSEMBLY Summary: HARD TO START, SLOW CRANKING CONDITION IN AMBIENT TEMPERATURE BELOW 20 DEGREES F. GM VOICEMAIL EXPRESS. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040857001 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10011134 Component: VISIBILITY:SUN ROOF ASSEMBLY Summary: SUNROOF WATER MANAGEMENT. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040849002 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10011137 Component: STRUCTURE:BODY:DOOR Summary: CENTER CONSOLE DOOR WILL NOT STAY CLOSED. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01759 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10006302 Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Summary: XM RAPID ACTIVATION UTILIZATION. *MR Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01711 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10006360 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: SLOW CRANK, HARD OR NO START. SERVICE VME. SIT BULLETIN 1458972. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01625 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007180 Component: ELECTRICAL SYSTEM Summary: 1.8 LV6 SUPERCHARGER ECU DIAGNOSTIC TROUBLE CODES AND P0115 STORED IN THE FACTORY POWER TRAIN CONTROL MODULE (PCM). *MR Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01662 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007248 Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Summary: XM ERROR ON A RADIO DISPLAY. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 02107 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007450 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: REPLACEMENT ENGINE AIR PORTS MAY BE MISSING. *MJ Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01600 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007674 Component: ELECTRICAL SYSTEM:WIRING Summary: ADDITIONAL WIRING/CONNECTORS NOT USED FOR SUPERCHARGER INSTALLATION. *MJ Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 02127 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007803 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: SERVICE ENGINE SOON (SES) LIGHT DUE TO A REPEAT P1349 DIAGNOSTIC TROUBLE CODE (DTC). *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3046 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009581 Component: FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY:PRESSURE RELIEF DEVICES Summary: FUEL TANK PRESSURE PARAMETER INFORMATION. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3049 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009655 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: CRANKSHAFT MAIN BEARING SELECTION INFORMATION. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3052 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009661 Component: ELECTRICAL SYSTEM Summary: PERFORMANCE PARTS SUPERCHARGER INSTALLATION INSTRUCTIONS SUPPLEMENT. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3117 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009962 Component: POWER TRAIN Summary: MU4 MU5 TRANSMISSION CHARACTERISTIC UPSHIFT OR DOWNSHIFT ON GRADES. *SC Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3106 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10010132 Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Summary: XM RADIO WAS WORKING PRIOR TO JULY 26, 2004 AND IT IS INOPERATIVE NOW. *JB Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer
: GENERAL MOTORS CORP. Service Bulletin Num : 01375 Date of Bulletin: NOV 18, 2003 NHTSA Item Number: 10004158 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: DRIVEABILITY ISSUES AFTER SHORT BLOCK REPLACEMENT. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01390 Date of Bulletin: NOV 18, 2003 NHTSA Item Number: 10004195 Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Summary: XM RADIO MUST BE TUNED TO CHANNEL 1 THROUGH 66 DURING ACTIVATION ATTEMPT. 2004 CHEVROLET CANYON, GMC DENALI, GMC COLORADO ALSO INCLUDED. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01458 Date of Bulletin: NOV 18, 2003 NHTSA Item Number: 10004260 Component: POWER TRAIN Summary: FWD SNAP CLICK CLUNK NOISE WHEN SHIFTING INTO REVERSE OR DRIVE. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 00067B Date of Bulletin: NOV 18, 2003 NHTSA Item Number: 10004268 Component: ELECTRICAL SYSTEM Summary: AWD WITH VARIOUS EVAP CODES P0440, P0441, P0442, OR P0446. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 100103 Date of Bulletin: OCT 01, 2003 NHTSA Item Number: 10004998 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: SNAPPING OR CLICKING NOISE WHEN THE TRANSMISSION IS SHIFTED FROM PARK TO REVERSE OR REVERSE TO DRIVE. GM VOICEMAIL LOG. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 100103 Date of Bulletin: OCT 01, 2003 NHTSA Item Number: 10004999 Component: ELECTRICAL SYSTEM Summary: NO AM RECPTION OR NO AM AND POOR FM RADIO RECEPTION. GM VOICEMAIL LOG. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 082003 Date of Bulletin: AUG 20, 2003 NHTSA Item Number: 10003823 Component: EQUIPMENT Summary: THE FRONT SPLASHGUARDS WERE ORIGINALLY RELEASED FOR THE 2003 MODEL YEAR VIBE AND WERE CARRIED OVER FOR 2004, THE FRONT SPLASHGUARDS ARE NOT COMPATIBLE WITH THE 2004 PONTIAC VIBE. A NEW SPLASHGUARD IS CURRENTLY BEING DEVELOPED TO RESOLVE THIS ISSUE. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01444 Date of Bulletin: JAN 01, 2003 NHTSA Item Number: 10004411 Component: OTHER Summary: XM DEALER ASSISTANCE LINE INFORMATION. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01432 Date of Bulletin: JAN 01, 2003 NHTSA Item Number: 10004412 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: AUTOMATIC TRANSMISSION POOR ACCELERATION, PERFORMANCE. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 020137006 Date of Bulletin: OCT 01, 2002 NHTSA Item Number: 10000188 Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER Summary: HVAC SYSTEM (HEATING, VENTILATION AND AIR CONDITIONING) SYSTEM DOES NOT GET COLD ENOUGH. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01183B Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10007621 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: MU4 MU5 AUTOMATIC TRANSMISSION FLUID COLOR. *MJ Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3162 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10010549 Component: ENGINE AND ENGINE COOLING Summary: TECH 2 EVAP PURGE SEAL TEST INFORMATION. *EH Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3171 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10010578 Component: ENGINE AND ENGINE COOLING Summary: HIGH RPM POWER LOSS AFTER A COLD START. *EH Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3202 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10010664 Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE Summary: EXHAUST ODOR Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3248 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10014860 Component: FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY:PRESSURE RELIEF DEVICES Summary: WITH TECH 2 SOFTWARE VERSION 24.009, 24.010, OR 25.001 INSTALLED, INACCURATE FUEL TANK PRESSURE SENSOR READINGS MAY BE NOTED DURING EVAP SYSTEM DIAGNOSIS. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3333 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10017220 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: MISFIRE ON TURNS DUE TO FUEL CONTAMINATION. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3344A Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10017238 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: MU4 MU5 AUTOMATIC TRANSMISSION FLUID COLOR. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3801 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10018911 Component: TIRES Summary: PREMATURE OR IRREGULAR REAR TIRE WEAR. *TT Check to Request Research. Submit below. Make : PONTIAC Model : VIBE Year : 2004 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3507 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10007619 Component: VEHICLE SPEED CONTROL:CRUISE CONTROL Summary: CRUISE CONTROL RESUME FUNCTION INTERMITTENTLY INOPERATIVE. *MJ Check to Request Research. Submit below.
Posted: Wed Oct 04, 2006 2:13 am
by northvibe
so if im out of warranty and one of these problems happen am i covered under a TSB thingy?
Re: (northvibe)
Posted: Wed Oct 04, 2006 2:18 am
by ToolGuy
Sadly no! Unless it states different... A recall yes but not a TSB. However if your issue is in a TSB you can obviously get the parts and do the repair or have the dealer do it.
