free 2003 Vibe TSBs I found....I can't believe someone hasn't posted all these
Posted: Tue Oct 03, 2006 10:14 pm
by bagwell
Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 030601020 Date of Bulletin: NOV 01, 2005 NHTSA Item Number: 10012558 Component: ENGINE AND ENGINE COOLING Summary: AVOIDING OIL BAFFLE DAMAGE DURING OIL FILL PROCESS. *EH Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040605011A Date of Bulletin: NOV 01, 2005 NHTSA Item Number: 10014960 Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM Summary: SULFUR (ROTTEN EGG) SMELL COMING FROM EXHAUST. *TT *JB Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 050851002 Date of Bulletin: APR 01, 2005 NHTSA Item Number: 10017330 Component: STRUCTURE:BODY:HATCHBACK/LIFTGATE Summary: REAR HATCH RUST. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 03082005 Date of Bulletin: MAR 08, 2005 NHTSA Item Number: 10014837 Component: FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK Summary: INACCURATE FUEL TANK PRESSURE SENSOR READING. *EH Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 701 Date of Bulletin: JAN 01, 2005 NHTSA Item Number: 10015762 Component: FUEL SYSTEM, OTHER Summary: FUEL FILTER REPLACEMENT. GM TECH LINK. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 611 Date of Bulletin: NOV 01, 2004 NHTSA Item Number: 10016257 Component: EXTERIOR LIGHTING:HEADLIGHTS Summary: AUTOMATIC HEADLAMP-OWNERS MAY COMMENT THAT THE AUTOMATIC HEADLAMP SYSTEM DOES NOT TURN THE HEADLAMPS ON WHEN THE VEHICLE IS STARTED DURING LOW LIGHT CONDITIONS. *SC Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 05062004 Date of Bulletin: MAY 06, 2004 NHTSA Item Number: 10013213 Component: EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL Summary: CIGARETTE LIGHTER HOUSING PULLING OUT OF THE DASH. *EH Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040849014 Date of Bulletin: MAY 01, 2004 NHTSA Item Number: 10008488 Component: STRUCTURE Summary: CIGAR LIGHTER HOUSING PULLS OUT OF DASH. *MJ Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 0208111005A Date of Bulletin: APR 01, 2004 NHTSA Item Number: 10000078 Component: STRUCTURE:BODY Summary: WHEEL HOUSE OPENING MOLDING DISCOLORED. *TT THIS SERVICE BULLETIN REPLACES 0208111005A. *EH Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01202004 Date of Bulletin: JAN 20, 2004 NHTSA Item Number: 10009095 Component: ELECTRICAL SYSTEM:STARTER ASSEMBLY Summary: HARD TO START, SLOW CRANKING CONDITION IN AMBIENT TEMPERATURE BELOW 20 DEGREES F. GM VOICEMAIL EXPRESS. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040857001 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10011134 Component: VISIBILITY:SUN ROOF ASSEMBLY Summary: SUNROOF WATER MANAGEMENT. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040849002 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10011137 Component: STRUCTURE:BODY:DOOR Summary: CENTER CONSOLE DOOR WILL NOT STAY CLOSED. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01711 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10006360 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: SLOW CRANK, HARD OR NO START. SERVICE VME. SIT BULLETIN 1458972. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01625 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007180 Component: ELECTRICAL SYSTEM Summary: 1.8 LV6 SUPERCHARGER ECU DIAGNOSTIC TROUBLE CODES AND P0115 STORED IN THE FACTORY POWER TRAIN CONTROL MODULE (PCM). *MR Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 02109 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007451 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: NO TECH 2 COMMUNICATION WITH ANY MODULES. *MJ Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01600 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007674 Component: ELECTRICAL SYSTEM:WIRING Summary: ADDITIONAL WIRING/CONNECTORS NOT USED FOR SUPERCHARGER INSTALLATION. *MJ Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 02127 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10007803 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: SERVICE ENGINE SOON (SES) LIGHT DUE TO A REPEAT P1349 DIAGNOSTIC TROUBLE CODE (DTC). *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 1531076 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10008774 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: REPLACEMENT ENGINES WILL HAVE AIR PORTS. *MJ Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3046 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009581 Component: FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY:PRESSURE RELIEF DEVICES Summary: FUEL TANK PRESSURE PARAMETER INFORMATION. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3049 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009655 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: CRANKSHAFT MAIN BEARING SELECTION INFORMATION. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3052 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009661 Component: ELECTRICAL SYSTEM Summary: PERFORMANCE PARTS SUPERCHARGER INSTALLATION INSTRUCTIONS SUPPLEMENT. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3117 Date of Bulletin: JAN 01, 2004 NHTSA Item Number: 10009962 Component: POWER TRAIN Summary: MU4 MU5 TRANSMISSION CHARACTERISTIC UPSHIFT OR DOWNSHIFT ON GRADES. *SC Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01375 Date of Bulletin: NOV 18, 2003 NHTSA Item Number: 10004158 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: DRIVEABILITY ISSUES AFTER SHORT BLOCK REPLACEMENT. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01458 Date of Bulletin: NOV 18, 2003 NHTSA Item Number: 10004260 Component: POWER TRAIN Summary: FWD SNAP CLICK CLUNK NOISE WHEN SHIFTING INTO REVERSE OR DRIVE. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 100103 Date of Bulletin: OCT 01, 2003 NHTSA Item Number: 10004998 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: SNAPPING OR CLICKING NOISE WHEN THE TRANSMISSION IS SHIFTED FROM PARK TO REVERSE OR REVERSE TO DRIVE. GM VOICEMAIL LOG. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 100103 Date of Bulletin: OCT 01, 2003 NHTSA Item Number: 10004999 Component: ELECTRICAL SYSTEM Summary: NO AM RECPTION OR NO AM AND POOR FM RADIO RECEPTION. GM VOICEMAIL LOG. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 082703 Date of Bulletin: AUG 27, 2003 NHTSA Item Number: 10003884 Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER Summary: THIS VME STATES IF HVAC SYSTEM IS NOT GETTING COOL ENOUGH TO REFER TO SERVICE BULLETIN 02-01-37-006. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 082603 Date of Bulletin: AUG 26, 2003 NHTSA Item Number: 10003883 Component: STRUCTURE:BODY Summary: THIS SERVICE VME CONCERNS CUSTOMERS COMMENTS THAT THE REAR WHEELHOUSE OPENING MOLDING OR THE REAR DOOR LOWER MOLDING IS DISCOLORED OR IT LOOKS LIKE IT'S BEEN SANDBLASTED. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 071203 Date of Bulletin: JUL 12, 2003 NHTSA Item Number: 10003818 Component: OTHER Summary: EMERGING ISSUES TELECAST REGARDING THE AIRBAG WIRE TRAP; PAINT FLAKING OFF SEAT FRAMES; HVAC CLICKING; OIL CHANGES WITH POWER OIL MACHINE; WATER LEAKS; RATTLE NOISE; BACK BUMPER RUST; ETC. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 030605006 Date of Bulletin: JUL 01, 2003 NHTSA Item Number: 10012564 Component: ENGINE AND ENGINE COOLING Summary: SULFUR ROTTEN EGG ODOR FROM EXHAUST SYSTEM. *EH Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01432 Date of Bulletin: JAN 01, 2003 NHTSA Item Number: 10004412 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: AUTOMATIC TRANSMISSION POOR ACCELERATION, PERFORMANCE. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 0208110007 Date of Bulletin: DEC 01, 2002 NHTSA Item Number: 10000772 Component: STRUCTURE:BODY Summary: RATTLE FROM MULTI-PURPOSE TRUNK ORGANIZER. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 020137006 Date of Bulletin: OCT 01, 2002 NHTSA Item Number: 10000188 Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER Summary: HVAC SYSTEM (HEATING, VENTILATION AND AIR CONDITIONING) SYSTEM DOES NOT GET COLD ENOUGH. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 100602 Date of Bulletin: JUN 10, 2002 NHTSA Item Number: 637216 Component: OTHER Summary: INFORMATION REGARDING THE JUNE EDITION OF EMERGING ISSUES FOR VARIOUS MODELS. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 040602 Date of Bulletin: JUN 04, 2002 NHTSA Item Number: 637183 Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Summary: CUSTOMERS MAY COMMENT THAT THE SINGLE DISK CD PLAYER MAKES A SCRAPING NOISE WHILE THE CUSTOMERS EITHER BRAKING OR TURNING THEIR VEHICLE. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 020602005 Date of Bulletin: JUN 01, 2002 NHTSA Item Number: 634772 Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM Summary: INFORMATION PERTAINING TO ENGINE COOLANT AND POWER STEERING FLUID USAGE. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 050302 Date of Bulletin: MAY 03, 2002 NHTSA Item Number: 636591 Component: VEHICLE SPEED CONTROL Summary: CUSTOMERS MAY COMMENT THAT THE CRUISE INDICATOR IN THE INSTRUMENT CLUSTER COMES ON WHEN THE CRUISE SWITCH IS PUSHED ON, BUT THE SYSTEM WILL NOT SET WHEN THE LEVER IS PRESSED TO THE SET POSITION. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 050302 Date of Bulletin: MAY 03, 2002 NHTSA Item Number: 636592 Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER Summary: CUSTOMERS MAY COMMENT THAT THE AIR CONDITIONING SYSTEM DOES GET COLD ENOUGH. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 042202 Date of Bulletin: APR 22, 2002 NHTSA Item Number: 636572 Component: VEHICLE SPEED CONTROL Summary: INFORMATIN ON THE CRUISE CONTROL RESUME FEATURE. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 010302 Date of Bulletin: MAR 01, 2002 NHTSA Item Number: 629861 Component: POWER TRAIN:AXLE ASSEMBLY:AXLE SHAFT Summary: SUBJECT REGARDING REAR BEARING HUB BOLT TORQUE SAFETY RECALL. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 280202 Date of Bulletin: FEB 28, 2002 NHTSA Item Number: 629850 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: OWNERS MAY COMMENT THAT THEIR TRANSMISSION SHIFTS TOO EARLY WHEN ACCELERATING AT FULL THROTTLE WHEN THE ENGINE IS COLD. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 180202 Date of Bulletin: FEB 18, 2002 NHTSA Item Number: 629809 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: INFORMATION ON USING T4 AUTOMATIC TRANSMISSION FLUID TO REDUCE HARSH SHIFT COMPLAINTS. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 180202 Date of Bulletin: FEB 18, 2002 NHTSA Item Number: 629810 Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE Summary: CUSTOMERS MAY COMMENT THAT THE ENGINE BREAKS UP OR LACKS PERFORMANCE ABOVE 7,000 RPMS. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 050202 Date of Bulletin: FEB 05, 2002 NHTSA Item Number: 629757 Component: STRUCTURE:BODY Summary: SOME MODELS EQUIPPED WITH A SUNROOF MAY ENCOUNTER A WATER LEAK FROM THE A-PILLAR OR HEADLINER AREA. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 290102 Date of Bulletin: JAN 29, 2002 NHTSA Item Number: 629728 Component: EXTERIOR LIGHTING Summary: SUBJECT REGARDING AUTOMATIC LIGHT CONTROL OPERATION. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3162 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10010549 Component: ENGINE AND ENGINE COOLING Summary: TECH 2 EVAP PURGE SEAL TEST INFORMATION. *EH Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3171 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10010578 Component: ENGINE AND ENGINE COOLING Summary: HIGH RPM POWER LOSS AFTER A COLD START. *EH Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3202 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10010664 Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE Summary: EXHAUST ODOR Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3248 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10014860 Component: FUEL SYSTEM,
OTHER:STORAGE:TANK ASSEMBLY:PRESSURE RELIEF DEVICES Summary: WITH TECH 2 SOFTWARE VERSION 24.009, 24.010, OR 25.001 INSTALLED, INACCURATE FUEL TANK PRESSURE SENSOR READINGS MAY BE NOTED DURING EVAP SYSTEM DIAGNOSIS. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3333 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10017220 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: MISFIRE ON TURNS DUE TO FUEL CONTAMINATION. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3344A Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10017238 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: MU4 MU5 AUTOMATIC TRANSMISSION FLUID COLOR. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3801 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10018911 Component: TIRES Summary: PREMATURE OR IRREGULAR REAR TIRE WEAR. *TT Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 3507 Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10007619 Component: VEHICLE SPEED CONTROL:CRUISE CONTROL Summary: CRUISE CONTROL RESUME FUNCTION INTERMITTENTLY INOPERATIVE. *MJ Make : PONTIAC Model : VIBE Year : 2003 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 01183B Date of Bulletin: JAN 01, 1901 NHTSA Item Number: 10007621 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: MU4 MU5 AUTOMATIC TRANSMISSION FLUID COLOR. *MJ
Posted: Wed Oct 04, 2006 8:54 am
by zionzr2
several of those are mentioned on this site, just not all in one place! Not everyone has issues with all those particular tsbs and therfore not mentioned anything. But thanks for consolidating all the 2003 tsbs.
Re: (zionzr2)
Posted: Tue Jun 12, 2007 10:50 am
by CUV03
Are these free even if your warranty has expired?
Posted: Tue Jun 12, 2007 11:23 am
by Fingers
TSBs are not free. They are advisories sent to techs to repair commonly discovered problems. Not the same as a recall or a secret warranty.
Re: (Fingers)
Posted: Wed Jun 13, 2007 4:27 am
by Mavrik
Quote, originally posted by Fingers »TSBs are not free. They are advisories sent to techs to repair commonly discovered problems. Not the same as a recall or a secret warranty.+1 if you walked in with that whole list, they would only do what could be duplicated on your vehicle as a concern. And if your out of warranty, you will be paying for the repair unless they decide to do a good will.
