ENGINE COVER REMOVAL HINTS
Posted: Tue Oct 03, 2006 9:33 am
by roddney1
I find that if you spray a little WD-40 around the plastic pins in the back of the engine shroud (or any plastic pins for that matter), and use a tack puller to lift under them, you can usually remove them without breaking them. A better solution for this situation is to replace the pins with 6mm hex bolts, as the back two holes are threaded the same as the front. That way the cover can be removed in the future much easier.
thanks, colors?
Posted: Sat Oct 07, 2006 10:35 am
by mathteacher'04vibe
Thanks for the tip. Does anyone know where to purchase new covers in various colors?
Re: thanks, colors? (mathteacher'04vibe)
Posted: Sat Oct 07, 2006 11:01 am
by NascarXprt
the cover you paint your self using a certan heat resitant paint.
Posted: Sat Oct 07, 2006 12:17 pm
by Mrizzle05
you can purchase CF covers!!! But they are pricey... like 160-ish or so for a trd one
Re: thanks, colors? (Mrizzle05)
Posted: Mon Oct 16, 2006 8:02 am
by engine111
go to your local autozone, they will have heat resistant paint in ay color you can think of for like 5 bux a can
Re: thanks, colors? (engine111)
Posted: Mon Nov 06, 2006 2:39 pm
by tcam
what is a "tack puller?
Posted: Tue Nov 07, 2006 8:53 am
by hakune
meh just run the engine for a while after you spray some wd-40 on just enough too heat the block up a little they should come right out
Re: thanks, colors? (NascarXprt)
Posted: Tue Nov 07, 2006 9:17 am
by VforVIBE
Quote, originally posted by NascarXprt »the cover you paint your self using a certan heat resitant paint.Heat resitant paint, hehehe
Re: thanks, colors? (silverawd26)
Posted: Tue Nov 07, 2006 10:07 am
by roddney1
A tack puller looks like a small screwdriver with a "V" cut in the center. It's used to pull out thumb tacks. You can buy them at just about any hardware store
Re: thanks, colors? (roddney1)
Posted: Tue Nov 07, 2006 12:27 pm
by tcam
ooo, ok. thanks. that'll help a lot
