12 volt accessory wire needed
Posted: Wed Sep 27, 2006 9:18 am
by satur9
okay heres my deliema .i need to find a 12 volt hot thats on when you turn the key to the acc. position. heres the catch i dont want to take off the radio .im already down to only two screws holding it in with a couple of busted clips on the trim. behind the glovebox and passenger kick panel is a ton of wires. i just need to add a inline tap to power my sat radio which only uses 2000mA .so almost any wire near that locale will do
Re: 12 volt accessory wire needed (satur9)
Posted: Wed Sep 27, 2006 11:23 am
by GMJAP
You can get it from under the center console (between the seats). The following thread shows how to get to it & what wire it is.http://forums.genvibe.com/zerothread?id=13711
Posted: Wed Sep 27, 2006 8:49 pm
by KNINE
I tapped into the accessory plug by the shifter for my Sirius modulator. It's switched.
Re: 12 volt accessory wire needed (K-NINE)
Posted: Thu Sep 28, 2006 12:15 am
by zionzr2
Quote, originally posted by K-NINE »I tapped into the accessory plug by the shifter for my Sirius modulator. It's switched.I have done the same for my AUX FM Modulator
Re: 12 volt accessory wire needed (zionzr2)
Posted: Thu Sep 28, 2006 5:50 am
by satur9
are you reffering to the lighter. if so dont you have to remove the radio? im really looking to be behind the glove box if possible.i just need to somebody that has schematics of all the stuff back there.
Posted: Thu Sep 28, 2006 7:03 am
by CAN-AWD-VIBE
you dont have to remove the radio... the lighter is on that panel below it.I would take it from there and run a wire wherever you want... all those wires behind the glovebox have a more meaningful purpose compared to the cig lighter.my 2 centsCAN-AWD-VIBE
Posted: Thu Sep 28, 2006 9:07 am
by Jahntassa
You probably don't want to mess with the stuff directly behind the glovebox, and by the way 2000ma is actually 2 amps, so that's hardly 'small'.
