				Need Door Hinge Part
				Posted: Sat Sep 23, 2006 6:13 am
				by Petrucci914
				I don't know what the exact name is.  My door flew open on a windy day and bend the hinge and broke some plastic.  Now when I shut my door with the window down it rubs on the window. See picture
				Posted: Sat Sep 23, 2006 8:32 am
				by northvibe
				junk yard is the only place i can think of for just getting that part. or there was someone here parting out a vibe....
				Re: Need Door Hinge Part (Petrucci914)
				Posted: Sat Sep 23, 2006 10:45 am
				by scherry2
				its a check strap or link. dealer should be able to order you one. I think that is the part that causes the window problems people were reporting. you might want to tell the dealer your window pops once in a while. he might relace it for free.
				Re: Need Door Hinge Part (scherry2)
				Posted: Sat Sep 23, 2006 1:01 pm
				by ColonelPanic
				Yeah, I'd milk that one if possible.  GM should know by now those pieces are crap, so if the car is under warranty, get it fixed for free. Otherwise, the new and improved door check part numbers:$87.40 GM listLF: 88937010RF: 88937009
				Re: Need Door Hinge Part (ColonelPanic)
				Posted: Sun Sep 24, 2006 3:07 am
				by Petrucci914
				No, way out of warranty.  Know of a good place to get a good price on both?  I found one place charging 54 a piece, just wondering if there are cheaper sources.  Thanks!
				Posted: Sun Sep 24, 2006 6:18 am
				by scherry2
				its not a warranty Item it is a T.S.B. technical service bulletin i would tell the dealer you have a popping noise coming from your window and that you hear that there is a T.S.B. concerning the check link and window breakage.
				Posted: Sun Sep 24, 2006 8:08 am
				by tnpartsguy
				I might have a pair of them at work. let me check, it will be tomarrow before I can get back to you. Which one do you need?
				Re: Need Door Hinge Part (tnpartsguy)
				Posted: Sun Sep 24, 2006 8:12 am
				by Petrucci914
				Ya, if I could get them for both the front doors that'd be awesome. The left front is the one that's bad now but I have to take the right front door apart to tighten that loose bolt so I myswell replace the part with the updated one. They're the updated ones, right? Thanks!
				Posted: Sun Sep 24, 2006 11:55 pm
				by tnpartsguy
				$49 each, plus shipping is the best I can do. And I do have both in stock of the new design.
				Posted: Mon Sep 25, 2006 12:33 am
				by Petrucci914
				How much would shipping be to Wisconsin. Zip-code 54155-9110. Thanks!
				Posted: Tue Sep 26, 2006 10:22 am
				by Petrucci914
				I'll take both of them. LF and RF.
				Posted: Mon Apr 09, 2007 3:51 am
				by Petrucci914
				Just a correction on the part numbers.  They areDriver: 88973010Passenger: 88973009NOT 88937....
				Posted: Mon Apr 09, 2007 9:30 am
				by ProtonXX
				I have 2 used ones but the screws are stripped, I thought replacing them would fix the window rub problem and it didnt
