Steering Wheel Shake
Posted: Fri Sep 22, 2006 5:45 am
by propigskin
We have a 2006 Vibe with less than 10k miles on it. Since we bought it the steering has gotten worse. When traveling approx 25+ mph, the steering wheel shakes about and inch back and forth. The steering is tight but it is very annoying. Anyone else have a similiar problem?thankseb
Re: Steering Wheel Shake (propigskin)
Posted: Fri Sep 22, 2006 5:55 am
by tcam
Alrignment checked? Tires Balanced?
Re: Steering Wheel Shake (tcam)
Posted: Fri Sep 22, 2006 6:17 am
by GrayFox
Quote, originally posted by tcam »Alrignment checked? Tires Balanced?+1 that sounds like quite a problem you've got there...head over to a tire shop and get it checked
Posted: Fri Sep 22, 2006 7:02 am
by propigskin
I was going to take it to the dealer- should be a warranty issues covered under the first 12k miles i was going to make an appt.
Posted: Fri Sep 22, 2006 7:36 am
by tcam
Quote, originally posted by propigskin »I was going to take it to the dealer- should be a warranty issues covered under the first 12k miles i was going to make an appt. I doubt they will. But it's not terribly expensive to get those two check-ups done. And if u still have problems after that, then I'd take it to the dealer
