Fan speed and idle
Posted: Thu Sep 14, 2006 1:31 am
by shane_c
Is this normal? When I have my A/C on my idle is quite high, usually around 1600. If I turn my A/C off it goes down to 800. The same happens when I use the fan without A/C. Only difference is the idle stays around 1200 and then goes to 800 when I turn it off.
Re: Fan speed and idle (shane_c)
Posted: Thu Sep 14, 2006 2:36 am
by zionzr2
While i'm not exactly sure of the numbers it is normal that A/C use will cause the Rpms to be higher at idle.It takes more power to turn the compressor motor than when its off.
Posted: Fri Sep 15, 2006 2:07 pm
by NewNeptune
Once mine is fully warmed up, it idles at ~900 with the A/C on and ~700 with it off.
Re: (NewNeptune)
Posted: Sat Sep 16, 2006 12:03 am
by Mavrik
Quote, originally posted by NewNeptune »Once mine is fully warmed up, it idles at ~900 with the A/C on and ~700 with it off. same here.
Re: (Mavrik)
Posted: Sat Sep 16, 2006 7:41 am
by djb383
Quote, originally posted by Mavrik »same here.Ditto.
