Painting Brake Calipers
Posted: Wed Sep 13, 2006 10:49 am
by tcam
Is it a necessity to sand the caliper before painting it? I have read a few posts on here that people recommend it, but my paint kit doesn't say anything about doing that. And for those that have done this mod already, how far back did u paint the caliper? Like did u paint the entire thing as much as you could. Or did u stop at the point where the paint would just be no longer visible?
Re: Painting Brake Calipers (tcam)
Posted: Wed Sep 13, 2006 10:56 am
by VforVIBE
I didn't sand my calipers and they turned out fine, I use two coats thatt pretty much covered it. I did mine a week ago.
http://forums.genvibe.com/zerothread?id=24797
Re: Painting Brake Calipers (VforVIBE)
Posted: Wed Sep 13, 2006 10:59 am
by tcam
yeah, I remember seeing that post not long ago. And I have had this caliper paint for a while now, and ur post kinda inspired me to get 'em painted soon. lolSo, did u paint the whole caliper, or just the parts that are visible from the outside?
Posted: Wed Sep 13, 2006 11:01 am
by VforVIBE
I painted as much as i could which was mostly all of it. Do you plan on painting the drums too?
Posted: Wed Sep 13, 2006 11:40 am
by LUVROK
Being that they're cast aluminum and have a rough surface, sanding won't do much. I would spray them down with brake parts or carb cleaner and brush them clean prior to painting though. Paint prep products may not be good for the seals, the parts cleaner may not be either so just watch those areas.
Re: Painting Brake Calipers (LUVROK)
Posted: Wed Sep 13, 2006 11:45 am
by tcam
Quote, originally posted by VforVIBE »I painted as much as i could which was mostly all of it. Do you plan on painting the drums too?I have calipers on both front and rear wheels.Quote, originally posted by LUVROK »Being that they're cast aluminum and have a rough surface, sanding won't do much. I would spray them down with brake parts or carb cleaner and brush them clean prior to painting though. Paint prep products may not be good for the seals, the parts cleaner may not be either so just watch those areas.will do
