Fidanza Flywheel
Posted: Sun Sep 10, 2006 6:26 am
by Voltty
hi 2 all,This is first post in this forum but i'm a long time reader.Probably i'm the only one that ownes a Toyota Voltz Z which is a Vibe GT but right hand drive.I'm about to change my clucth to an ACT kit with an Xtreme P/P and a street disc and i was wondering while i'm in the operation would it be worth it to change the Flywheel as well.From the research i've made the best Flywheel i have found is the Fidanza apart from the $$$$.I would like to know wheter anyone have 1 installed and if is worth the $$$ comparde to the power gain?All replies are appeciated.Thanks guy
Re: Fidanza Flywheel (Voltty)
Posted: Sun Sep 10, 2006 8:01 am
I can't help you about the flywheel decision, but I had to say welcome to genvibe, that is a nice looking Voltz. Are there many Voltz's on Malta or is yours the only one?
Posted: Sun Sep 10, 2006 8:04 am
by Raven
Welcome to Genvibe! Nice looking car. I'd like to see another shot of the back lights. If I were you, I would definately get the flywheel. It will free up a lot of power and since the car will be taken apart anyways, it's the time to do it.
Posted: Sun Sep 10, 2006 1:05 pm
by Jahntassa
I was under the impression that due to the weight, in terms of the flywheel it was better to keep stock, if only because it IS heavier?I mean, yeah, the Fidanza will get spun up faster, but the stock will keep spinning better. Maybe? Dunno..thought I read that.
Posted: Sun Sep 10, 2006 1:36 pm
by LUVROK
The stock flywheel, being heavier, will give more low RPM torque and is less likely to cause you to stall out at very low RPMs.Common practice for offroad vehicles with small engines is to add weight to the flywheel, lots of weight like 50 lbs to keep a low RPM idle without stalling. I'm able to climb straight up obstacles between 700-1200 RPM.
Re: Fidanza Flywheel (Sunny)
Posted: Mon Sep 11, 2006 5:31 am
by Voltty
Thanks to all for your welcome.I'm looking for more accelaration since we only have a drag strip.I'm not interested in off-road.And my next mod probably will be 50 direct port nitrous shotTo: sunny i have post some more pics.joatmon: in Malta there is only about 15 and 1/2 of them are S type which means the base model.Malta is very small island which is located 60 mile south from sicilly and have only 400,000 inhabitants.i like to hear a reply from someone that have it installed.Pls ignore my father sleeping on the front seat!!!!
Posted: Mon Sep 11, 2006 5:35 am
by Voltty
My Mods since now : TRD Shocks + Spring 1.5 drop , TRD Exchaust , AEM Short Ram , TWM Short Shifter on the way ETA 20/9/06Future mods: the Clutch kit and Flywheel , Nitrous 50 shot , TRD LSD , Body Kit , 19" Wheels.more picshttp://www.cardomain.com/ride/2199378Is there a way to upload multiple pics so i will send you some maltese mods in the last tuning show XLR8 2006?
Posted: Mon Sep 11, 2006 6:22 am
by vibegtcouple
the volts is way gt4 had the vibe gt in it look under toyota and it is in there
Re: Fidanza Flywheel (vibegtcouple)
Posted: Mon Sep 11, 2006 11:18 am
by Raven
I've got to find a set of those tailights. Anybody have any ideas?
Posted: Tue Sep 12, 2006 6:03 am
by satur9
i dont have a gt or a fidanza but i do have another brand of lightened flywheel. you'll definitely notice the faster revs and other gains however you will stall out more. and since i hear that the 2zz clutch is more finicky it might be a learning experience. also you will fall out of lift during shifts quicker as well.you should check out http://www.newcelica.org also the gts have your same engine and tranny and plenty of those guys have findanza flywheels. also a few xrs owners on http://www.matrixowners.com may have the fidanza. if your only doing a 50 shot all you really need is a wet kit. direct port is for bigger shots unless you just like the look.i also have an act clutch cause i wasted the stock clutch with all the nitrous and drag launches and stuff. click the link below in my sig to check out my cardomain page. did those chrome tailight covers come with the car. i had to pay a rediculous amount of money to have mine pair shipped from a dealership in japan. i wonder if they still sell voltz stuff now that its been discontinued?
Posted: Tue Sep 12, 2006 8:38 am
by VforVIBE
Ok, I'm new to the whole Voltz thing , is it a Toyota or Pontiac?
Re: Fidanza Flywheel (VforVIBE)
Posted: Tue Sep 12, 2006 8:53 am
by Mavrik
Quote, originally posted by VforVIBE »Ok, I'm new to the whole Voltz thing , is it a Toyota or Pontiac?Its toyota but an over sea version which looks like the Vibe.
Re: Fidanza Flywheel (Mavrik)
Posted: Tue Sep 12, 2006 8:58 am
by VforVIBE
I saw both toyota and pontiac symbols, I think.
Posted: Fri Sep 15, 2006 6:26 am
by Voltty
satur9Re Chrome taillight, it has came with it. What about the ACT clutch? What is your combination. HD R4 /XT SS?I'm looking for the Fidanza F W instead of other since it is the lightest in here we only race in Drag the peak revs i need more. Fidanza 7.5lbs vs MWR 10.5 and RPS 10lbs. I know that at first it's typically to stall but my tuner told me you'll get use to it.After i did some more research I think you are right about the nitrous i would probably go for wet kit. which kit do you have and what about the setting is it set to WOT?The attached pic is the winner of the last XLR8 show. (ccccooooolllll "civic" )
Posted: Sat Sep 16, 2006 2:30 am
by satur9
i have the mrw flywheel and act xtreme clutch. and i would reccomend the zex wet kit
