Limit size of embedded images?
Posted: Fri Sep 01, 2006 11:03 am
by ZubenElGenubi
Is there any way to limit the physical size of embedded images? I'm specifically suggesting a maximum width of 800 pixels. This would allow an image to fit within the post column without forcing the column to continue beyond the right edge of the maximum viewing window when at 1024x768 resolution.This should not be enforced on attached images (which display separately).Here are some examples which brought this to mind (no offense intended on my fellow members! ) :http://forums.genvibe.com/zero...40325h ... ro...age=2
Posted: Wed Sep 06, 2006 12:05 am
by Atomb
hey, that sketch of the cover i made was an attachment in my post...somebody else turned it into an embedded image! j/k i agree on trying to limit it though.With signatures turned off and small fonts, etc. i try to keep the page as 'clean' as possible and a wide picture doesn't fit 'the zen' of all that!
Posted: Wed Sep 06, 2006 12:09 am
by AKLGT
800 pixels wide is definitely big enough to see the pic and small enough, you don't have to "scroll" to see the whole thing, or then attempt to read anything after or before it.
