Device Under Driver's Seat
Posted: Fri Jan 31, 2003 3:21 am
by Cajun
Does anyone know what the device under the driver's seat does?
Re: Device Under Driver's Seat (Cajun)
Posted: Fri Jan 31, 2003 3:23 am
by Sub-Vibe-R
AC converter for the 120v power outlet
Posted: Fri Jan 31, 2003 3:44 am
by KSNeptune
And if you think the AC outlet doesn't have enough power for certain devices you want to use, there are other inverters with more power. You could replace thestock inverter.Just an idea.KSNeptune
Re: Device Under Driver's Seat (KSNeptune)
Posted: Fri Jan 31, 2003 4:01 am
by Sub-Vibe-R
quote:And if you think the AC outlet doesn't have enough power for certain devices you want to use, there are other inverters with more power. You could replace thestock inverter.Just an idea.KSNeptune But don't forgot to change the fuse, and do not chage the converter for a to big, cause if it takes too much power to run, it can burn the wiring and cause damage.
Re: Device Under Driver's Seat (Sub-Vibe-R)
Posted: Fri Jan 31, 2003 7:38 am
by Cajun
Thanks for the information. That sure is a big chumk of stuff to only give 100 watts of power. i have yet to find anything that consumes that low a current other than a 100 watt light bulb and I am not so sure about it.
Posted: Fri Jan 31, 2003 9:30 am
by Lorin
I installed a 450 Watt converter in my conversion van - enough juice to power the nintendo and game cube....the TV and VCR are 12 volt. Personally, I don't like the idea of too much 110 VAC running around from a safety point of view.
