1zz Billet Throttle Rotor Installed!
Posted: Sun Aug 27, 2006 12:55 am
by northvibe
There is a deal through Weapon R on newcelica.org to get the billet throttle rotors for 1zz and 2zz engines for $30 shipped. It is supposed to take up some of the slack in the throttle cable and since its bigger than stock, less turning to become WOT. I do notice a little difference, in response time this does NOT add HP.
Re: 1zz Billet Throttle Rotor Installed! (northvibe)
Posted: Sun Aug 27, 2006 3:25 am
by joholste
that looks cool...would it possibly help the acceleration?
Posted: Sun Aug 27, 2006 3:35 am
by northvibe
i think my (removed) dyno said it did a little, i squawk the tires more now...a lot more.
Re: (northvibe)
Posted: Sun Aug 27, 2006 3:52 am
by BlueCrush
Looks good, NV! I wonder if you are able to spin the tires a little on take off due to the fact that you are idleing higher to begin with? That is most likely the case. Like I always say, every little bit helps.
Re: (BlueCrush)
Posted: Sun Aug 27, 2006 4:22 am
by northvibe
Quote, originally posted by BlueCrush »Looks good, NV! I wonder if you are able to spin the tires a little on take off due to the fact that you are idleing higher to begin with? That is most likely the case. Like I always say, every little bit helps. I think so, anyway i like it! cuz now more ppl are like WTH? and they see its a freakin wagon baby!
Re: (northvibe)
Posted: Sun Aug 27, 2006 6:14 am
by BlueCrush
I placed my order for one! I'll try it out also. For $30 shipped it is worth a try. It'll look good next to the TB Spacer.
Re: (BlueCrush)
Posted: Sun Aug 27, 2006 7:19 am
by joholste
where are you getting them at?
Posted: Sun Aug 27, 2006 7:45 am
by northvibe
you gotta be a member at newcelica.org then go to this threadhttp://www.newcelica.org/forum...17597BC when you get it forsure post up on what you think! I know some ppl on MO said they bought it too...damn WR should give me a engine damper for free for all this publicity
Posted: Mon Aug 28, 2006 4:11 am
by Mase
Careful about making it too tight. Heat and cold affect throttle cable tension. A little maladjustment will cause it to idle high and through a CEL.
Posted: Mon Aug 28, 2006 4:29 am
by KNINE
This might sound stupid, but what's a 1zz and 2zz engine. I'm pretty new to the Vibe world.
Re: 1zz Billet Throttle Rotor Installed! (K-NINE)
Posted: Mon Aug 28, 2006 4:36 am
by Shadow-Vibe
1zzfe is the base engine found in the non-GT Vibes or the Matrix XR, the 2zzge is the engine code for the one in the Vibe GTs or the Matrix XRS.
Re: 1zz Billet Throttle Rotor Installed! (Mase)
Posted: Mon Aug 28, 2006 4:53 am
by northvibe
Quote, originally posted by Mase »Careful about making it too tight. Heat and cold affect throttle cable tension. A little maladjustment will cause it to idle high and through a CEL.Oh believe me, i had it at the 2nd hole first and it was idling at 3k rpm...yeah a little to high. So right now its on the first hole, which is pretty much stock, like i said it maybe idles 100 to maybe 200k rpm more at idle. thanks for the warning though, that is something to watch out and be careful of.
Posted: Mon Aug 28, 2006 8:12 am
by Mase
I found out first hand too. I adjusted the throttle so there was no slack in the line. For the first 10 minutes of driving it was fine. As soon as the engine warmed up, so did the cable. Without the slack in the cable to compensate for the temperature increase, the throttle opened up on its own. I was pretty embarrassed to go through a drive-thru with the car revving at a constant 3500rpm. A couple minutes later *ding*....CEL.I got so fed up with it that I bought 2 wrenches while I was in town so I could fix it in the parking lot before going home!Quote, originally posted by northvibe »Oh believe me, i had it at the 2nd hole first and it was idling at 3k rpm...yeah a little to high. So right now its on the first hole, which is pretty much stock, like i said it maybe idles 100 to maybe 200k rpm more at idle. thanks for the warning though, that is something to watch out and be careful of.
Posted: Mon Aug 28, 2006 8:36 am
by BlueCrush
I'm a little confused. Doesn't heat expand metal? So wouldn't the cable actually have more slack once heated? Just wondering.
Re: 1zz Billet Throttle Rotor Installed! (BlueCrush)
Posted: Mon Aug 28, 2006 9:55 am
by zionzr2
Quote, originally posted by BlueCrush »I'm a little confused. Doesn't heat expand metal? So wouldn't the cable actually have more slack once heated? Just wondering.Thats what i was thinking...Also how can one adjust the tension on the cable with the stock setup with out any new device??
Posted: Mon Aug 28, 2006 11:48 am
by northvibe
there are two little nuts that are on the cable and can adjust to where the cable is held on to the TB by a bracket. you just adjust it so its further away from the TB. hard to explain but just go check out the TB and you'll see what im talking abouut
Re: (northvibe)
Posted: Mon Aug 28, 2006 1:44 pm
by SuperSpeedWagon
sweet mod but over all i think it would be well worth it and for $30 shipped you cant go wrong man good find for the rest of us lol thanx
Re: (SuperSpeedWagon)
Posted: Wed Aug 30, 2006 12:42 am
by BlueCrush
I got mine today. I will install it tonight and report back.
Posted: Wed Aug 30, 2006 3:38 am
by northvibe
ha NICE! you got yours FAST!
Posted: Wed Aug 30, 2006 3:59 am
by Mase
The plastic rubber tube that encloses the cable must expand when it heats up and put tension on the steel cable. All I know is that the revs kept climbing the hotter the engine bay got.Quote, originally posted by BlueCrush »I'm a little confused. Doesn't heat expand metal? So wouldn't the cable actually have more slack once heated? Just wondering.
Re: (northvibe)
Posted: Wed Sep 06, 2006 11:41 pm
by BlueCrush
Well, I installed it and then had to take it off because my RPM's were over 1000 at idle. That is because I had already tightened my cable throttle last year. This will not work if you have tightened your cable throttle. This will work if you have not tightened your cable throttle.So with that said, I am selling my Weapon-R throttle rotor for $20 shipped to whoever wants it. It is silver polished like northvibe's.That is $10 less than what I paid for it. My loss its your gain. IM me if interested.EDIT: Throttle Rotor - Sold
Re: (BlueCrush)
Posted: Wed Sep 06, 2006 11:51 pm
by joholste
IM sent
