2" spacer
Posted: Fri Aug 25, 2006 8:20 am
by scherry2
I bought (from Damronjr I think, my minds going with age. so forgive me) some 2" spacers for my rear rims a few years ago. but I've never taken a picture of them. personally i like the way they fill the lip in the rear.
Re: 2" spacer (scherry2)
Posted: Fri Aug 25, 2006 8:30 am
by damronjr
Yep, and looks good!
Posted: Fri Aug 25, 2006 9:38 pm
by Merzbow
I allways wondered about that in the back. I think it looks alot better.
Posted: Sat Aug 26, 2006 12:55 am
by northvibe
post more pics of different angles
Re: (northvibe)
Posted: Sat Aug 26, 2006 5:27 am
by SuperSpeedWagon
it does look good me likey hahah
Re: (northvibe)
Posted: Sat Aug 26, 2006 7:01 am
by scherry2
will do. I just got a new nikon coolpics L3. it will give me a chance to play with it.
Posted: Sat Aug 26, 2006 8:00 am
by northvibe
i just noticed this on my car! i need some . so do they go behind the rim or behind the rotor thingy that hold the studs.
Re: (northvibe)
Posted: Sat Aug 26, 2006 8:53 am
by scherry2
between the drum and rim
Posted: Sun Aug 27, 2006 6:51 am
by zionzr2
forgive my ignorance here, but is this device moving the wheels out 2" from their stock postion? Effectively making your Wheel base 4 inches wider?
Posted: Sun Aug 27, 2006 8:47 am
by northvibe
so if its between the drum and rim...do you need longer studs?
Re: (northvibe)
Posted: Sun Aug 27, 2006 9:28 am
by damronjr
Quote, originally posted by northvibe »so if its between the drum and rim...do you need longer studs?No, that's why they are generally not recommended, same as adapters. You just have to keep an eye on them and make sure they stay tight, but no difference from lug nuts. If you tighten them right, they should be just fine.
Re: (zionzr2)
Posted: Sun Aug 27, 2006 11:29 am
by scherry2
Quote, originally posted by zionzr2 »forgive my ignorance here, but is this device moving the wheels out 2" from their stock postion? Effectively making your Wheel base 4 inches wider?yesQuote, originally posted by northvibe »so if its between the drum and rim...do you need longer studs?no the spacer bolts to the oem studs with lug nuts and the rim is secured to the spacer studs with oem lugnuts.
Posted: Sun Aug 27, 2006 11:39 pm
by northvibe
OHH scherry2 if ou ever take off a rim again, could you snap a pic of that?damron or scherry2 - where do you get these and what brand?
Re: (northvibe)
Posted: Mon Aug 28, 2006 2:38 am
by damronjr
Quote, originally posted by northvibe »OHH scherry2 if ou ever take off a rim again, could you snap a pic of that?damron or scherry2 - where do you get these and what brand?I got them from Ebay. Honestly, I have no clue who the seller was. I have a pic of them on my Vibe when I tried them out, but with the rims I have they stuck out too far. They seem to be perfect with the OEM 16's. I'll find the pic(s) and post it/them.Edit: Found them!
Posted: Mon Aug 28, 2006 2:56 am
by scherry2
there ya go. I still think I'll takes some pics.
Re: (zionzr2)
Posted: Fri Sep 01, 2006 11:48 am
by 2006Vibe
Quote, originally posted by zionzr2 »forgive my ignorance here, but is this device moving the wheels out 2" from their stock postion? Effectively making your Wheel base 4 inches wider?You aren't increasing the wheel base, you're increasing the track width (cross car). The wheel base is the hub centerline relationship between the front and rear hub on the same side... that you can't "easily" increase.. unless you make your vibe into a limo
Posted: Fri Sep 01, 2006 3:44 pm
by northvibe
wow that looks good, mods...aaahhh why do mods cost money! hahahha did you guys notice any handling differences after putting the spacers on?
Re: (northvibe)
Posted: Fri Sep 01, 2006 8:51 pm
by scherry2
I didn't feel any difference.I take them off in the winter so I don't know if there would be a problem in the snow.
Re: (northvibe)
Posted: Sat Sep 02, 2006 2:45 am
by damronjr
Quote, originally posted by northvibe »wow that looks good, mods...aaahhh why do mods cost money! hahahha did you guys notice any handling differences after putting the spacers on?On mine the tires scraped the lip of the fender! lol Didn't keep them on very long!
Re: (damronjr)
Posted: Sat Sep 02, 2006 3:58 am
by scherry2
was that because of your rims or Air Bags.
Re: (scherry2)
Posted: Sat Sep 02, 2006 4:44 am
by damronjr
Quote, originally posted by scherry2 »was that because of your rims or Air Bags. The tires and the rims were too wide. I didn't have air-bags yet, just springs. It was lowered, and that also played a part, but if the rim/tire combo would have been thinner it wouldn't have rubbed like that anyways.
