rear view mirror vibe-ration
Posted: Wed Aug 23, 2006 1:28 pm
by TSvibe
Love my vibe but the rear view mirror vibrates badly with any bass on the stereo at all. I rented a 2005 vibe before I bought mine and it did it as well.Seems like the mirror is pretty light anybody attach a little extra weight to it to help or am I alone in this complaint? Thanks!
Re: rear view mirror vibe-ration (TSvibe)
Posted: Wed Aug 23, 2006 1:43 pm
by damronjr
Quote, originally posted by TSvibe »Love my vibe but the rear view mirror vibrates badly with any bass on the stereo at all. I rented a 2005 vibe before I bought mine and it did it as well.Seems like the mirror is pretty light anybody attach a little extra weight to it to help or am I alone in this complaint? Thanks!You knowm something I noticed the other day, I was putting my window shade things in the window and the rear-view mirror popped right off! It slid up, guess the screw was loose, probably from vibration as well! Might try tightening that first and see if it makes any difference, I still haven't tightened mine yet. Otherwise, to me it seems the vibration comes from the casing around the actual mirror.
Posted: Wed Aug 23, 2006 2:00 pm
by ColonelPanic
Which mirror is this, by the way?Try getting a torx screwdriver (can't recall what size though!) and tighten it up.. Hopefully it just needs some tightening!I had no problems with my original mirror (which was the one w/o map lights for a moon & tunes car) but when I replaced it with an auto dimming one, that mirror wasn't as solid so it vibrated more. If you're not under warranty or whatever and need a mirror, I still have my original mirror sitting at home boxed up, I have no use for it. If you don't have the map lights, it should work fine.
Posted: Wed Aug 23, 2006 2:14 pm
by nuvibe
I noticed that mine did that also couple week's ago. I that it was my stereo but no. I'm going to check it out.... nuvibe
Re: (nuvibe)
Posted: Thu Aug 24, 2006 7:24 am
by new05vibeowner
When I installed the compass mirror I bought in a junkyard, it vibrated badly, almost to the point you couldn't look out of it. I loosened the Torx screw, removed the mirror from the windshield, and slightly pried the edges of the mounting bracket in, to make a tighter fit.If just tightening the Torx screw doesn't work, give it a try, but BE CAREFUL! If you pry too hard, you may end up holding a broken mirror in your hand.
