Garage Door Opener Button
Posted: Wed Jan 29, 2003 4:50 am
by Cajun
I found a use for the left side compartment. I installed a black push button (Radio Shack) in one of the blank spaces above the compartment. I wired from it to a garage door opener stored in the compartment. It looks like it belongs (more or less) and is a lot easier trying to remember which of the many compartments I stored the opener.I can post a picture if you are interested.
Re: Garage Door Opener Button (Cajun)
Posted: Wed Jan 29, 2003 8:09 am
by NSimkins
quote:I can post a picture if you are interested.Please do. It would be appreciated.
Re: Garage Door Opener Button (NSimkins)
Posted: Wed Jan 29, 2003 11:53 pm
by Cajun
This is a radio shack button which cost about $2.50. You have to open your garage door opener and solder the button wires across the appropiate spot on your opener. You can test which but placing a wire across the suspected points. If the door moves, it is the right ones. Try not to have your car under the door during this operation.
Posted: Wed Jan 29, 2003 11:56 pm
by Sub-Vibe-R
It could be a good idea to "tie wrap" the remote under the dash. This will avoid some rattles and give you back the compartment.
Posted: Thu Jan 30, 2003 12:10 am
by NovaResource
Nice job, Cajun.
Re: Garage Door Opener Button (Sub-Vibe-R)
Posted: Thu Jan 30, 2003 6:21 am
by KSNeptune
I agree tucking the remote behind the dash would be better. But remember you occasionally have to replace batteries in those remotes, so keeping it in the flip-open compartment is probably gonna prove the easiest. And I know radio shack has lots of switch styles. It would be nice to find a useable switch that looks "factory", and simply replaces the whole panel opening.KSNeptune
Re: Garage Door Opener Button (KSNeptune)
Posted: Thu Jan 30, 2003 4:33 pm
by Herb
Well how about relocating the battery to a more accessable location. That way the remote can be permanently stowed away.
Re: Garage Door Opener Button (Herb)
Posted: Thu Jan 30, 2003 8:25 pm
by Cajun
I started in the direction of using car power (my remote has a small 12 volt battery). I had wired it to do it that way.I decided I was over doing it. It is a hassle to find a power source, tap into it and then store it all somewhere you will remember.The door on the small compartment has a REAL flimsly latching mechanism. I decided it was better to close it and not open it too often.Bill
Posted: Wed Nov 07, 2007 3:32 am
by waveresponder
nice..ive been wondering what i could do with those blank panels on the drivers side...
Re: Garage Door Opener Button (waveresponder)
Posted: Wed Nov 07, 2007 11:38 am
by Kamikaze
I've got my next project!Thanks Cajun for the idea...
Posted: Wed Nov 07, 2007 12:14 pm
by wyatt89
sweet job, ive never actually put anything in that compartment...
Posted: Sun Nov 25, 2007 11:16 pm
by cabman
I really like Cajun's idea but I didn't want the switch for my garage door to be quite so visible so I made a slight alteration. I turned the silly coin holder upside down and installed a small pushbutton swith inside. I then wired it to the garage door opener which is wire-tied up under the dashboard as mentioned in another post (with a new battery installed). As you can see in the photo, I'm hoping the casual observer would not even notice the switch.
Posted: Sun Nov 25, 2007 11:17 pm
by cabman
Sorry, here's the other photo
Re: Garage Door Opener Button (cabman)
Posted: Mon Nov 26, 2007 9:36 am
by Herb
That's quite ingenious!
Posted: Mon Nov 26, 2007 11:25 am
by scott_h
And I always thought they put that clip on the opener so you could put it on the visor and not have to remember where you put it...
Posted: Wed Mar 05, 2008 9:09 am
by arlynd
This is a great idea. While checking on all the great things about the Vibe/Matrix on the web I also came across this switchhttp://www.oznium.com/gsw-45If it fits the Matrix I think it should also fit the Vibe. I ordered two today (one on/off and one momentary). I'll let you know how they work when they come in.
Posted: Wed Aug 19, 2009 9:31 am
by PlatinumVibe08
I have two garages with two different openers. I installed two of the N.O. momentary switches from Radio Shack ($2.69 ea.) and zip tied the two remotes to a wire loom behind the aforementioned left side compartment. Now my compartment is empty and I simply push the top button to open the door on my detached garage and the bottom button for the door on the house. Thanks for the idea Cajun! PlatinumVibe08
Posted: Wed Aug 19, 2009 10:27 am
by Herb
I've seen this item on eBay go for around $20This panel can be installed on the headliner, thereby freeing storage compartments and the need to change the battery. I went a slightly different route and got an autodimming mirror with Homelink built in:
