magnaflow axle
Posted: Fri Aug 11, 2006 12:14 pm
by 1zzfe_808
so my friend who has the magnaflow catback exhaust, just ordered a greddy axle back and said i could have the magnaflows axle back part. my question is this would just be like bolting on a borla or TRD exhaust right??? i might get a few horses but not much?
Re: magnaflow axle (1zzfe_808)
Posted: Fri Aug 11, 2006 10:23 pm
by NUBlackshirts
That would be about right. The magnaflow muffler flows a bit better than the stock one. So you might gain a few hp, but not a lot.
Posted: Sat Aug 12, 2006 9:01 am
by Raven
If it's free, it's worth doing.
Re: magnaflow axle (Sunny)
Posted: Mon Aug 14, 2006 1:22 am
by Psychobroker
Yep, that'll be better than stock, and sound nicer too. Smells like a JP Midpipe, or custom piping, might be in your future
Posted: Mon Aug 14, 2006 10:04 pm
by JustinVGT
Anyone recall if the Magnaflow axle back portion will connect right up with the rest of the stock system? If I remember when I installed my Magnaflow cat-back, that connection may have been slightly different. I'm not sure if it will be a simple bolt on like the Borla.
Re: (JustinVGT)
Posted: Mon Aug 14, 2006 10:17 pm
by NUBlackshirts
Ooo, hadn't thought of that. You might be right since the Magnaflow is an entire cat-back system, it might not work with the stock pipe.
Posted: Mon Aug 14, 2006 11:28 pm
by Mase
The Magnaflow axle-back will not bolt up to the stock flange. First of all, the piping and flanges are different sizes. Plus the flange bolt pattern on the Magnaflow is a reverse of what the stock exhaust has. Take it to a shop and have them cut it up and weld it on.
Re: (Mase)
Posted: Thu Aug 17, 2006 10:22 am
by Mavrik
If anything it will sound great
Posted: Fri Aug 18, 2006 9:20 pm
by Never Enough
For free, its worth the $50 to have a shop cut it and weld it in place. Might as well throw down a little extra and have them build you a midpipe as well while its on the lift.
