Hella Horn Mounting
Posted: Thu Jul 27, 2006 11:52 am
by VforVIBE
If anyone has the Hella horns or any other or any kind of twin horn, where did you mount the second one? I want to put them both behind the grilles, but I don't know how to get between the frame(?) and the grille to drill a hole. Help...This is what I want it to loook like.
Re: Hella Horn Mounting (VforVIBE)
Posted: Thu Jul 27, 2006 12:50 pm
by ZubenElGenubi
Re: Hella Horn Mounting (ZubenElGenubi)
Posted: Thu Jul 27, 2006 1:28 pm
by VforVIBE
Thanks for the help , however I have an 06, different grille My fault for showing the older grille.
Posted: Thu Jul 27, 2006 2:10 pm
by northvibe
if you mount them the same it should be fine. the 05+ grill is just bigger. if you want them right in the middle of those grills then you'd have to fab your own brackets.
Posted: Thu Jul 27, 2006 10:21 pm
by Jahntassa
I took the grilles out of my 03. I would think it shouldn't be hard to pull the grilles out of your 06. Maybe..Take a look around the grilles and see if you can find any screws to pull out or anything. Otherwise, yes, some sort of bracket that you can screw into the top of the bracer would be sufficient.
