My audio system installation (lot of pics)
Posted: Mon Jan 27, 2003 10:39 pm
by Sub-Vibe-R
I'd like to share with you my audio syteme installation. I know this installation is very basic but for anyone who do not want to spend 2 weeks to install an audio system, it is perfect.1st: Installing the 8 gauge wire from the batterie. The 40 amp. fuse older can be screw very easely to the plastic part near the fuse box, at the top of the fender.
Re: My audio system installation (Sub-Vibe-R)
Posted: Mon Jan 27, 2003 10:42 pm
by Sub-Vibe-R
2nd: Then, the wire pass through the firewall by this place.
Posted: Mon Jan 27, 2003 10:44 pm
by Sub-Vibe-R
3rd: Route the wiring up to the trunk. I pass the wiring (8 gauge wire, remote and RCA) under the plastic, at the bottom of the door. Then I driller a hole to get in the trunk.
Posted: Mon Jan 27, 2003 10:47 pm
by Sub-Vibe-R
4th: I used the hole for child seat pin to get into the trunk.
Posted: Mon Jan 27, 2003 10:49 pm
by Sub-Vibe-R
This is the final install of my 12" JL audio subwoofer.
Posted: Mon Jan 27, 2003 10:56 pm
by Sub-Vibe-R
Now, I increased the base, but to balnace, we need to add high frequencies. I add 2 aftermarket twitters and I put thEm at the bottom of the A pilar. They are plugged with the front speakers and I put a crossover to cut bass in tweeters and cut high in front doors.
Posted: Mon Jan 27, 2003 11:02 pm
by Sub-Vibe-R
Upgrading the speakers it's ok, but for good quality, you may need to upgrade the head unit also. I went for the Pionner DEH-8400MP.
Posted: Mon Jan 27, 2003 11:04 pm
by Sub-Vibe-R
This is another pic of my head unit. You can also nitice i change the shift knob and add sports pedals.
Posted: Tue Jan 28, 2003 5:00 pm
by BigWill
Nice work......Nice Deck! I was going to get that Deck, but I went with this one instead.
Posted: Tue Jan 28, 2003 5:39 pm
by SCTM
Great Job Ben! Now, no more snowbrush to clean the car in the morning... just turn-on your audio system Yeh Yeh Yeh!!!
Re: My audio system installation (BigWill)
Posted: Tue Jan 28, 2003 10:58 pm
by Sub-Vibe-R
quote:Nice work......Nice Deck! I was going to get that Deck, but I went with this one instead. Your head unit has the same features as mine. The only difference are the look and the mobile front plate. I like gadget. Without a good price as I had, I'd bought this model.
Posted: Thu Jan 30, 2003 12:07 am
by DopeVibeGT
Install looks good, Ben. Only thing is, that install would last one night where I live before the back window got smashed.
Re: My audio system installation (DopeVibeGT)
Posted: Thu Jan 30, 2003 12:11 am
by BigWill
Where do you live?
Posted: Thu Jan 30, 2003 12:14 am
by DopeVibeGT
Lancaster.
Posted: Thu Jan 30, 2003 4:58 am
by Sub-Vibe-R
That's why I have alarm system with pager, and good insurance
Posted: Thu Jan 30, 2003 5:28 am
by Vibe Rater
Is your brake fluid reservoir low? Looking at the first picture, it looks low.
Posted: Thu Jan 30, 2003 10:18 am
by DopeVibeGT
Alarms help, but an insurance company would get upset if everytime you install a sub, it gets ripped. LoL I've been very lucky with my GA when it was on the street. My subs fit nicely into the trunk, put the seat back up and no subs. Out of sight, out of mind. Will the cargo cover fit over the speaker in the back?
Posted: Thu Jan 30, 2003 11:41 am
by BigWill
mine fits good, you can't see them at all.....
Re: My audio system installation (Vibe Rater)
Posted: Thu Jan 30, 2003 11:44 pm
by Sub-Vibe-R
quote:Is your brake fluid reservoir low? Looking at the first picture, it looks low. I don't know. It always been that level. I went for oil change 3 day before taking those pics. May be mechanic didn't filed it up. I also notice brake, power stering and engine coolant were not full, but between the full and low (closer to the low) level when I picked up my Vibe.
Posted: Fri Jan 31, 2003 9:52 am
by Lorin
Thanks for the Pic's Ben! Routing the power to the rear has been keeping me from hooking up my Kenwood powered sub-woofer (sort of like a bass-bazooka) - Getting through the firewall has been the "scarey" part.I also need to decide how to drive it - It has RCA jacks as well as the ability to take input off of speakers. I spliced into the speaker lines in my S-10 and it sounded ok. I want to do the audio on a shoestring not because I can't afford it, but because I'm feeling CHEAP!
Posted: Thu Feb 06, 2003 12:34 am
by Mr. Poopypants
Great pics. I didn't even think of running the wires the same way, I have my amp under the back seat and the wires run up the back of the seat.
Posted: Thu Feb 06, 2003 1:20 am
by Keely
Ben, I see from your sig line that you have an amp somewhere... is that under a seat? How does that fit in with the wiring you've done? Sorry if I missed this and its already been asked and answered.
Re: My audio system installation (Keely)
Posted: Thu Feb 06, 2003 1:34 am
by Sub-Vibe-R
quote:Ben, I see from your sig line that you have an amp somewhere... is that under a seat? How does that fit in with the wiring you've done? Sorry if I missed this and its already been asked and answered. Take a look on the top of teh sub box, follow the wiring, there's my amp.I'll try to put it somewhere else when temp will become less cold. I figure out putting it under the trunk plate.
Posted: Thu Feb 06, 2003 1:48 am
by Keely
quote:Take a look on the top of teh sub box, follow the wiring, there's my amp.All I can say is - what a blonde moment! So it isn't a problem to mount your amp on the sub? No interference, shaking, whatever?
Posted: Thu Feb 06, 2003 2:04 am
by Sub-Vibe-R
quote:All I can say is - what a blonde moment! So it isn't a problem to mount your amp on the sub? No interference, shaking, whatever? No problem at all. 4 good screw to hold the amp makes the job.
Posted: Sun Jul 06, 2003 10:33 pm
by Sub-Vibe-R
I made a little clean up and remove the amp from the top of the sub and put it in the tire compartmentNow it looks like this
Posted: Tue Jul 08, 2003 10:05 am
by meathead333
that looks alot better!
Posted: Wed Aug 04, 2004 10:47 pm
by lazytiger
Awesome, man. You did the exact same thing I'd like to do - put the amp upside down in the spare tire well. Could you possibly post some more detailed pictures and explanation of how you did it? (Including how you ran the wires through the dash and under the doors.)Also, some questions: Does your amp get enough ventilation in there? How hard is it to get the spare tire out in an emergency? Thanks!
