Bad news.....
Posted: Mon Jan 27, 2003 7:50 am
by andrewmva
Threw a rod Sat night on our 1zz project SO today I ordered a new block, rods and bearings. we were running on the highway and the boost spiked really high really fast and that was it. Threw the rod straight through the block. We are paying for the new block, rods everything. I'm just disappointed. There are a few weak spots that we need to address, and the fact that it is mid engine car brings other complications to the table. Mid engine cars tend to have insufficient oiling systems. under heavy accel the oil gets stuck in the pan and is not circulated properly which may have also contributed to losing the engine. - I will keep everyone posted on the progress from here. For now I'm sulking..... and I'm really pissed off.
Re: Bad news..... (andrewmva)
Posted: Mon Jan 27, 2003 8:14 am
by d_m_kolb
Come on man if you used Amsoil you wouldn't have a oil problem. Sorry you know I'm kidding. I'm sorry to hear about the engine. Were you doing some high RPM runs when this happened? What caused the PSI increase?This is kinda off topic but what have you done to the engine in your Matrix?
Posted: Mon Jan 27, 2003 9:41 am
by MadBill
Bummer! But as one of GM's early leaders said: "The price of progress is trouble." Also, Harold Bettes of SuperFlow:" If a racer is head and shoulders above the others, chances are it's because he's standing on a pile of broken parts."When the engine's apart, I'd be interested if a piston broke first, leaving the rod flailing around, or if the rod just folded under the boost.
Posted: Mon Jan 27, 2003 12:13 pm
by Faultline
All I have to say ....is that you must have been a Raiders fan
Re: Bad news..... (fault line)
Posted: Mon Jan 27, 2003 9:39 pm
by slbpsi63
quote:All I have to say ....is that you must have been a Raiders fan He didn't say her burned his car or looted his own city!!!! LOL RAIDER FANS ARE THE WORST (with the exception of MYKIDSGT, very classy in our conversations)
Posted: Mon Jan 27, 2003 10:55 pm
by NovaResource
That sucks but you know what they say in racing: "If you don't break anything, you aren't trying hard enough."About the oiling system: looks like it's time for a dry-sump.
Posted: Mon Jan 27, 2003 11:20 pm
by DABEAR95
Ouch, to what do you attribute the spike in the boost?Jason
Posted: Tue Jan 28, 2003 2:09 am
by NY Pete
hey guy... there's a whole motor on ebay... cheap!
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33615 maybe that'll help...
Re: Bad news..... (NY Pete)
Posted: Tue Jan 28, 2003 2:20 am
by andrewmva
here are some pics of the nightmare.... thease are pictires that I am not proud of, -but I feel obligated to show, it happens, it happened to us, I'm not going to hide anything -but I'm not going to let it happen again!!! ---Andrew
Re: Bad news..... (DABEAR95)
Posted: Tue Jan 28, 2003 2:22 am
by andrewmva
quote:Ouch, to what do you attribute the spike in the boost?Jason not sure, possibly a vac line.
Posted: Tue Jan 28, 2003 2:30 am
by NY Pete
OOF! Any idea what peak boost was before the bottom end gave out? And was the failure entirely borne by the bottom end (i.e. was there enough pre-detonation with that kind of cylinder pressure to damage the valves/head?)...?Again, we feel your pain...
Posted: Tue Jan 28, 2003 3:03 am
by andrewmva
quote:OOF! Any idea what peak boost was before the bottom end gave out? And was the failure entirely borne by the bottom end (i.e. was there enough pre-detonation with that kind of cylinder pressure to damage the valves/head?)...?Again, we feel your pain...No Idea on the peak boost... I have to hook up the laptop and check, -but I dunno if they were dataloging or not. The damage was the bottom end ONLY.... no detonation -but like I said I was not there, I have afeeling there was just too much power for the rods to handle.
Re: Bad news..... (Admin II)
Posted: Tue Jan 28, 2003 8:17 am
by andrewmva
quote:Come on man if you used Amsoil you wouldn't have a oil problem. This is kinda off topic but what have you done to the engine in your Matrix? I use AMSOIL in EVERYTHING!!!!! love that stuff!!! My car is stock but I have a few goodies in mind
Posted: Tue Jan 28, 2003 10:22 am
by cohocarl
quote:here are some pics of the nightmare....Wow.
Re: Bad news..... (cohocarl)
Posted: Thu Feb 06, 2003 6:36 am
by andrewmva
solution to our rod problems... and some lubication tricks
Posted: Thu Feb 06, 2003 11:18 am
by coratz
makes me wonder when you hit lift, did the rod go? i heard through a buudy that there is a surge in oil preasure to activte the diff lobe? probaly why the gt motor had a much larger oil capicty. im not even sure if you had the gt motor. what if there was even an aftermarket larger oil pan?
Re: Bad news..... (coratz)
Posted: Thu Feb 06, 2003 11:19 am
by coratz
id be very intereted in seeing the hook up the turbo, when is was working
Posted: Wed Feb 12, 2003 5:54 am
by MYKIDSGT
quote:--------------------------------------------------------------------------------All I have to say ....is that you must have been a Raiders fan --------------------------------------------------------------------------------He didn't say her burned his car or looted his own city!!!! LOL RAIDER FANS ARE THE WORST (with the exception of MYKIDSGT, very classy in our conversations) _______********************************************************Thanks for the nice words slbpsi63.Andrew, sorry to hear about what happend. I know I am a little behind.Look forward to your Good News in the future.
Re: Bad news..... (MYKIDSGT)
Posted: Wed Feb 12, 2003 7:46 am
by PBFlash
quote:makes me wonder when you hit lift, did the rod go?This was on a 1ZZ so there is no lift.
Re: Bad news..... (PBFlash)
Posted: Thu Feb 13, 2003 8:07 am
by Chris
Bummer about the engine! Thanks however, for showing us the damage.On a lighter note... one of the porche teams racing in the LeMans 24 hour was heard to say that they had to drop out due to electrical problems... that is electrical problems that occurred when a piston exited the block and severed some wires
Posted: Fri Feb 14, 2003 12:42 am
by Mr. Poopypants
quote:Come on man if you used Amsoil you wouldn't have a oil problem. Shameless plug, ha, I love it.
