radio dimmer
Posted: Sat Jul 15, 2006 11:59 am
by mcgusto82
i recently had to remove my sony cd deck for quality issues. i installed my OEM single disc deck back in.it's been sitting in my livingroom closet for over 1 year. it seemed to start up just fine. sounds great too, but once the headlights come on, the dimmer kicks in and the display and all radio lights go completely out. and back on when the lights come back off. now, it doesn't effect the radio functions at all. anybody got any ideas of what this could be???p.s. i've been busy with other endevors, so i want to say HI to all.
Re: radio dimmer (mcgusto82)
Posted: Sat Jul 15, 2006 12:10 pm
by GMJAP
Were any changes made to the radio wiring when you installed the Sony?I expect this is a wiring issue, and not a head unit problem.
Re: radio dimmer (GMJAP)
Posted: Sat Jul 15, 2006 11:46 pm
by mcgusto82
well, some time ago. i taped into the lead for the dimmer wire. i disconnected it when i put the oem radio back on. maybe it's making ground or something. i'm about to check.
Posted: Sun Jul 16, 2006 3:57 am
by mcgusto82
thanks for the help. i found it to be a loose pin on the connector behind the radio.
Posted: Mon Jul 31, 2006 6:28 am
by Cwew
I'm having a somewhat similiar problem. I connected the radio dimmer and it dimmed my stereo past what I liked so I disconnected the radio dimmer completely, and now my tail lights don't work, and my cabin dimmer doesn't work anymore. Does the vibe run the dimmer through the radio? I'm going to try to reconnect it tonight and see what happens.Anyone know a way to skip the radio but keep the function of the other lights, if this is indeed the problem?03, Vibe GT no moon & tunesThanks,--Cwew
Re: radio dimmer (Cwew)
Posted: Mon Jul 31, 2006 11:53 am
by mcgusto82
far as i know. the dimmer shouldn't have any control of the rest of the lights. when i was trouble shooting, i had the entire harness off and had control of my dimmer lighjts and ther were no issues. sounds like a short somewhere in your rqadio harness. go over the wieres. i'm assuming you recently installed a new radio.you can also try putting back the oem radio and see what that does.
Posted: Mon Jul 31, 2006 11:40 pm
by Cwew
I think I blew a fuse, I pulled out the new radio, put in the old one, still had the same problem, and doing some looking online they had someone that ran into a similiar problem. I'll be checking on the fuses tonight, and if there's one blown replacing it, otherwise back to the drawing board again I guess.
Posted: Sun Aug 06, 2006 6:23 am
by Cwew
Turns out it was the "Tail" fuse. Replaced it, everything back to normal.
