Vibe Fog Light Removal
Posted: Mon Jul 03, 2006 12:38 am
by skipatrol
Help!Does anybody know how to remove the fog lights on a 2003 Vibe? I had a stone smash the glass and although I've stuck my head behind the bumper and splash guard, I cannot figure out how to actually remove the assembly. Any assistance would be greatly appreciated. Any links to schematics or visual diagrams would be great too!FYI. Sit down if you are planning to buy a replacement from the dealer. I was shocked when they told me it was $250 each!!CMT
Re: Vibe Fog Light Removal (skipatrol)
Posted: Mon Jul 03, 2006 1:31 am
by maxt
did you check the local junkyard or eBay? That is your best bet to get a replacement fog at reasonable price
Re: Vibe Fog Light Removal (maxt)
Posted: Mon Jul 03, 2006 2:02 am
by skipatrol
Thanks Maxt,I need to get it out first though, thats were I'm stumped.CMT
Posted: Mon Jul 03, 2006 2:10 am
by Mrizzle05
do you have the owners manual. dont remember if they show you how to replace the fog lamp. but once you get it out you can also go aftermarket for like 60 bucks and get some with halo rings... if you like that style. or you can get some basic fogs and wire them up to a switch. just an idea for you.Did you also try a search in DIY section here? it might bring something up.GL
Re: Vibe Fog Light Removal (Mrizzle05)
Posted: Mon Jul 03, 2006 2:15 am
by skipatrol
Mrizzle05:Owners manual shows you how to push buttons and turn switches. Actual lamp removal is easy, it's the removal of the housing that is a (removed). Without totally removing the front bumper (which I may have to do), I cannot figure out how to release the assembly. I do not see any screws. I see clips but do not want to take the risk of damaging or breaking a plastic clip. I searched for aftermarket lights, but was very unsuccessful.Thanks for your assisstance.CMT
Posted: Mon Jul 03, 2006 2:23 am
by millster
http://forums.genvibe.com/zerothread?id=11635Some brief detail in this thread (posts by Scherry2 and RodZombie).
Posted: Mon Jul 03, 2006 2:28 am
by scherry2
you need a 10 mm ratchet or wrench, a small pocket screw driver and a flash light.take the 2 bolts out of the sheild under the bumper to have easy access. shine the flashlight at the rear and you will see 1 round peices on each side stick the screwdriver behind the tab holding it and pull the screwdriver away from the fog lamp housing and with your other hand push on the back of the fog lamp housing once you have them both loose take and push with the screw driver on each side of the adjusting screw at the bottom of the housing to get it loose the fog lamp will then come out the front of the bumper hole
Re: Vibe Fog Light Removal (scherry2)
Posted: Mon Jul 03, 2006 2:33 am
by Mrizzle05
good info. sherry!!!Something i gotta remember now just in case.
Posted: Mon Jul 03, 2006 6:40 am
by skipatrol
Scherry:Woohoo! Success!. After pushing those two tabs in and the one around the adjusting screw, it almost fell out.Anybody know of a source for aftermarket assemblys?Thanks for the assisstance and the quick replies everybody!!CMT
Posted: Mon Jul 03, 2006 10:25 am
by MRCN RCE
hey ski, welcome to genvibe. glad you got your problem solved. here's a good and worthwhile purchase to help keep you from having to go through this again... i'm gonna get some soon too
http://forums.genvibe.com/zerothread?id=16180
Posted: Tue Jul 19, 2011 11:17 pm
by btimlake
Great instructions! Worked like a charm. To install, I just pushed the new assembly in from the front, and it snapped into place. I didn't do anything with the adjustment screw, but the beam did not seem to be out of whack.
Posted: Wed Jul 20, 2011 10:53 am
by MotoAce51
These GM parts are killer. My wife bought my window switches when she got the window stuck down and called me freaking out in the rain. Those were $100. If it were me I'd see if some of the walmart or pepboys ones would fit somehow. It would be a hellofalot cheaper.
Re: Vibe Fog Light Removal (MotoAce51)
Posted: Wed Jul 20, 2011 11:00 am
by ou.grizzly
Quote, originally posted by MotoAce51 »These GM parts are killer. My wife bought my window switches when she got the window stuck down and called me freaking out in the rain. Those were $100. If it were me I'd see if some of the walmart or pepboys ones would fit somehow. It would be a hellofalot cheaper.Many parts for the Vibe can be purchased through Toyota for a lot less money most of the timeVibe = Matrix (same car)
Posted: Fri Aug 11, 2023 4:36 pm
by TheCamoVibe
Old thread but I just found it today. Replaced mine (busted) with a set from Amazon. $45. Looks a LOT better. It was easy enough. I didn't have to unscrew all 3 screws out of the protective shroud, just the front one. Folded it back. Replaced after installation. I literally just shoved a screwdriver in the back between old light assembly and bumper, pried a few times, then shoved one between the front light and the bumper, and popped it right out. I replaced the little bracket rubbers from my old lights to my new lights, and popped them back in. My vibe has 14 lights on the front alone. 6 across roof. 2 100W LED Nilights, 2 85Watt LED headlight upgrades, 2 45 watt offroad cornering lights for seeing the ditches before they see me (ONLY for turning or perhaps for finding cellphones or socket wrenches on the side of the road ROFL), and these two spots. I used 30 watt LED spots. I have plenty of light.. no need to push it with local law enforcement.
Posted: Fri Aug 11, 2023 5:01 pm
by Mark
I have a broken lens on Frosty, I put some clear packing tape on it a few years ago and it's still holding up fine. I bought some clear Gorilla tape since then, so one of these days maybe I'll peal off the packing tape and put the Gorilla on. That will probably be permanent.
I've also bought several Depo fog assemblies on Amazon over the years.
