Wires attached to shifter??
Posted: Fri Jun 30, 2006 2:45 am
by Indy500
I just installed my TWM shifter and there are two wires that were clipped to the base of the OEM shifter on the right side. What are these wires for?
Posted: Fri Jun 30, 2006 3:18 am
by tnpartsguy
What year is your car, and is it a Auto or a stick?
Re: Wires attached to shifter?? (Indy500)
Posted: Fri Jun 30, 2006 3:19 am
by Mrizzle05
they could be the wires for the reverse light and sensor for what gear your in for your tachometer.But im not sure... just a educated guess.
Posted: Fri Jun 30, 2006 4:36 am
I found a pic of my 5 speed stock shifter. Does the arrow show where the wires are that you are asking about?I have no idea what they are for, but on the 5 speed there is nothing to measure what gear you are in, and the reverse switch is built into the tranny, not the shifter. I haven't looked at my car to see what those are, or if they are even clipped to the shifter or something else
Posted: Fri Jun 30, 2006 7:19 am
by tnpartsguy
Maybe part of the shift lock solenoid system......?
Re: (tnpartsguy)
Posted: Fri Jun 30, 2006 8:43 am
by Mavrik
Quote, originally posted by tnpartsguy »Maybe part of the shift lock solenoid system......?a manual would not have that... but an automatic would.
Re: Wires attached to shifter?? (joatmon)
Posted: Tue Jul 04, 2006 7:37 am
by Indy500
Joatmon is right. The white plugs that his arrow point to are the ones in question. And I have a 2003 5 speed. Anybody know what they could be used for? On my car, they were not connected to anything. I hoped there was some option that went there.
Posted: Tue Jul 04, 2006 8:52 am
by ColonelPanic
It could be wired for something it doesn't have to save money. Who knows, that could go to the O/D switch, the shift lock solenoid, or the gear indicator light if it had an automatic but they just left it there for the manual...What about the annoying beeper switch on the 6-speed, is that built into the backup light switch or is that separate? If it is separate, maybe this has something to do with it, once again added to the 5-speed to save money...
Re: Wires attached to shifter?? (ColonelPanic)
Posted: Thu Jul 06, 2006 12:52 am
by Indy500
Thanks to everyone that replied. I think I am just going to tie wrap them so they don't rattle around. I have driven long enough without the console put together.
