Need Help changing my passenger side mirror
Posted: Tue Jun 27, 2006 5:28 am
by Dans_03Vibe
have no clue of how to take off the mirror (broke 3 days ago)
Posted: Tue Jun 27, 2006 6:25 am
by northvibe
ive never done it...but with my old windstar, i had to take off the inside triangle piece on that door (inside the car opposite of the mirror) it could also have a speaker in it if you have the moons n toons. then there should be bolts in there you undo and the mirror can come off and be unclipped (electrics). I THINK THIS IS IT but correct me or add on if you know.
Re: Need Help changing my passenger side mirror (Dans_03Vibe)
Posted: Tue Jan 16, 2007 2:20 pm
by mth
I need to change my mirror as well. It looks as if there be bolts behind the triangular interior trim piece, but I can't readily see how the plastic trim piece would be removed. Have you had any luck? Any advice would be appreciated.
Re: Need Help changing my passenger side mirror (mth)
Posted: Tue Jan 16, 2007 10:28 pm
by kcorona
From the 03 Matrix factory manual:OUTER REAR VIEW MIRROR ASSY LHREPLACEMENTHINT: Installation is in the reverse order of the removal. In the RH side, work in the same procedure as in the LH side.1. REMOVE FRONT DOOR PULL HANDLE LH (See page 75–5)2. REMOVE POWER WINDOW REGULATOR MASTER SWITCH ASSY (W/ POWER WINDOW)(See page 75–5)3. REMOVE FRONT ARMREST BASE PANEL UPPER LH (W/O POWER WINDOW)(See page 75–5)4. REMOVE FRONT DOOR WINDOW REGULATOR HANDLE ASSY (W/O POWER WINDOW)(See page 75–5)5. REMOVE FRONT DOOR LOWER FRAME BRACKET GARNISH LH (See page 75–5)6. REMOVE FRONT DOOR TRIM BOARD SUB–ASSY LH (See page 75–5)7. REMOVE OUTER REAR VIEW MIRROR ASSY LH(a) Remove the 3 nuts and the rear view mirror assembly LH, and then disconnect the connector.8. INSTALL OUTER REAR VIEW MIRROR ASSY LHTorque: 8.0 NVm (81 kgfVcm, 71 in.Vlbf)
Re: Need Help changing my passenger side mirror (kcorona)
Posted: Thu Feb 15, 2007 6:45 am
by broncodevil
hello, do you have your old mirrors and if so, i need one of the little blue pegs..........can you help me?
Re: Need Help changing my passenger side mirror (broncodevil)
Posted: Wed Aug 26, 2009 11:20 am
by asagorcus
I may be able to help you...but i have to accomplish my task first.Also could someone help me with removing the passenger door panel?Thanx for your quick replies!
Re: Need Help changing my passenger side mirror (asagorcus)
Posted: Wed Aug 26, 2009 11:32 am
by ou.grizzly
Quote, originally posted by asagorcus »I may be able to help you...but i have to accomplish my task first.Also could someone help me with removing the passenger door panel?Thanx for your quick replies!Refer to Cohocarl's thread on how-to-install-speakers which you were looking at earlier.
Re: Need Help changing my passenger side mirror (ou.grizzly)
Posted: Wed Aug 26, 2009 11:53 am
by asagorcus
That was for the rear door panels does that apply to the front door panels as well?
Posted: Wed Aug 26, 2009 11:55 am
by ou.grizzly
Quote, originally posted by asagorcus »That was for the rear door panels does that apply to the front door panels as well?Pretty much...
Posted: Wed Aug 26, 2009 11:58 am
by asagorcus
Ok cool! Thank you for your time! I will give an update when I have succesfully replaced the mirror.
Posted: Thu Aug 27, 2009 4:10 am
by asagorcus
Alright everything went smoothly! Thanx for your help everyone! So yeah just follow the directions.
Posted: Thu Aug 27, 2009 4:11 am
by ou.grizzly
Quote, originally posted by asagorcus »Alright everything went smoothly! Thanx for your help everyone! So yeah just follow the directions. :-PFor the person that was inquiring about the old mirror email me at:
asagorcus@gmail.comOnce again thanks for the help!Your welcome... May the force be with you.
Posted: Wed Jan 27, 2010 4:04 am
by MrsGart
We replaced the side mirror on the Vibe out in the driveway. The aftermarket Mirror was right around $50. and looks exactly like the 2005 Vibe original equipement. Its easy, so don't be afraid to try it yourself.
