'03 GT 2nd->3rd gear problem??
Posted: Tue Jun 20, 2006 11:47 am
by slappy434
Hey all,I'm brand new to this board, so Hi. My girlfriend is looking at Vibes and Vibes only. She found an '03 GT 6-speed and LOVES it. The only problem, which I have a question about, is.....when shifting from 2nd to 3rd there is a wierd chrunching/grinding noise. It doesn't sound like when you typically grind the gears (like you don't know how to drive a stick yet) it sounds like the gear is having a hard time going into 3rd. It doesn't happen on any other gears, only 2nd to 3rd or 4th to 3rd. The dealer told me it was the "Gear Synchronizer"?!?! I dont' know enough about manual transmissions to know, and I haven't found much anywhere regarding it. I've found a few posts here and there on other boards but nothing detailing this. Has anyone ever heard of this type of thing?? They said they'd repair it before we bought it, but also I don't know what goes into doing this. Does it mean that they'll have to rebuild some portion of the transmission?? Anyways, if anyone can help please let me know. I'll probably start frequenting this forum for advice from you all who are more experienced and to give my input from what I find about her new purchase (when she decides on one) Thanks for any help you all can provide.-D
Re: '03 GT 2nd->3rd gear problem?? (slappy434)
Posted: Tue Jun 20, 2006 12:08 pm
by Mrizzle05
it could be the clutch slipping... a few earlier GT owners were having problems with that. its not on all, but it may be in your case... i dont know a whole lot about trannies and all but thats what it might be.Hope this helps and others will post soon... and welcome to the site
Posted: Tue Jun 20, 2006 1:00 pm
by Jahntassa
Clutch slip on the GTs generally applies where, if the clutch is 'released', meaning the gear is engaged, the clutch is not fully gripping, so you can literally rev the engine without going anywhere in gear.You should NOT be hearing a crunching / grinding noise every time you shift into a gear. Yes, at times the shifts can be hard, but it's not right.It's possible they may have to rebuild part of the transmission. No matter what, they'll probably have to take the tranny apart. I'd make sure it's fixed before you sign anything. If they won't fix it, then you're sure to have problems later on down the line, and they're just trying to make a buck off you.
Posted: Tue Jun 20, 2006 1:13 pm
by slappy434
It doesn't seem as if its slipping. It is definately making it into gear, but making an odd grind noise and then just kicks into gear without rocking or jarring the car at all. It almost seems like it just has a problem getting into gear when you force it. It usually goes into gear when the RPM's are lower and/or if you ease it into 3rd. Also, too, even if they fix it, is this probably a good indication that another one will go out later on? Thanks to all who have any input. This is cool, I like hearing from other Vibe owners about this situation. -D
Re: (slappy434)
Posted: Tue Jun 20, 2006 2:21 pm
by iinan
I bought my 04 GT brand spankin new and it has never shifted smooth, its very notchy and you smell the clutch burning when starting on most hills. I have owned sticks for over 20 years and this is the worst shifting car of them all.....I also like this car more then most of my other cars ....If you get a GT get used to the quarky shifting
Posted: Tue Jun 20, 2006 10:08 pm
by Jahntassa
Yeah, the stick and clutch on this car are very 'odd' compared to most.Even still, it does sound like it could be a syncro problem.My advice on getting the tranny to do better is to dump the stock clutch and get something beefier. I've had a 6-puck ceramic in mine the last few months and I haven't been able to burn it yet.Also, do a search for 'shifter bushings'. The stock rubber ones leave a lot of 'play' between the gears, making it a pain to actually get in gear sometimes. Getting the brass bushings helps out with that a lot and makes the whole shifting process a lot more precise.
Posted: Tue Jun 20, 2006 10:33 pm
by slappy434
iinan - I've noticed that it does shift a little odd from all other manuals I've driven, its got a very short "throw" distance between gears and its definately quirky to shift.jahntassa - I'll definately look into that when she decides on one because I notcied the same thing you're talking about, there seems to be play there before the gears actually engage. Also I never knew that about brass bushings either. Good to know!
Posted: Wed Jun 21, 2006 1:23 am
by Atomb
i'd say spare yourself any and all aggrevation and find another vibe (GT).i'm sure there are plenty more in the reston area...it's not like you're in the middle of nowhere!
Re: (Atomb)
Posted: Wed Jun 21, 2006 1:38 am
by slappy434
yeah, that may be what we end up doing. It is pretty cheap though ($9,999). But that may be for good reason. In fact, there are some, but not as many as one might expect, they're in high demand, and with good reason. Another question I've got which is sort of off topic is - are the GT's significantly better than the regular 5 speeds, aside from the obvious standard features? Is the engine that much better? or just the things that come with it and possible mod ability.Thanks-D
Re: (slappy434)
Posted: Wed Jun 21, 2006 2:07 am
by iinan
Hitting lift in a GT is fun But a base can get SuperCharged Which is better ? I dunno, but I would not trade my GT for a Base never ever ever ever
Re: (slappy434)
Posted: Wed Jun 21, 2006 2:12 am
by theangrydwarf1
The base 5-speed has the 1zz engine and the GT has the 2zz, there are some differences between the two. The 2zz has a higher compression ratio of 11.5 to 1. It also has lift, which is a larger cam profile that engages at 6500rpms. These are just a few, others can elaborate on the differences.
Posted: Fri Jun 23, 2006 9:27 am
by Psychobroker
Quote, originally posted by slappy434 »Hey all,I'm brand new to this board, so Hi. My girlfriend is looking at Vibes and Vibes only. She found an '03 GT 6-speed and LOVES it. The only problem, which I have a question about, is.....when shifting from 2nd to 3rd there is a wierd chrunching/grinding noise. It doesn't sound like when you typically grind the gears (like you don't know how to drive a stick yet) it sounds like the gear is having a hard time going into 3rd. It doesn't happen on any other gears, only 2nd to 3rd or 4th to 3rd. The dealer told me it was the "Gear Synchronizer"?!?! I dont' know enough about manual transmissions to know, and I haven't found much anywhere regarding it. I've found a few posts here and there on other boards but nothing detailing this. Has anyone ever heard of this type of thing?? They said they'd repair it before we bought it, but also I don't know what goes into doing this. Does it mean that they'll have to rebuild some portion of the transmission?? Anyways, if anyone can help please let me know. I'll probably start frequenting this forum for advice from you all who are more experienced and to give my input from what I find about her new purchase (when she decides on one) Thanks for any help you all can provide.-Dyes, it's a syncro, and a BAD one at that. I wouldn't buy that Vibe unless they inspected and FIXED that synchro. Clutch slippage is totally different, as pointed out by Jahntassa.
Posted: Fri Jun 23, 2006 10:05 am
by goodvibe
Find a different one.
Re: (goodvibe)
Posted: Fri Jun 23, 2006 2:21 pm
by ColonelPanic
Quote, originally posted by goodvibe »Find a different one. I don't know nothin' bout shiftin' no trannies but I will say that's darn good advice. I know you don't want transmission problems period, had that with my ol' Vibe's automatic. Find something else.Besides, the transmission may not be the only problem, the previous owner probably dogged the hell out of that thing. No telling what else could be wrong it, hiding under there... eek! BTW, slappy, as far as differences go, dont' forget that with the GT she will have to spend 20 cents more for each gallon since the GT requires a mininum of 91 octane fuel, whereas the base and AWD engine does fine on 87.
Posted: Sat Jun 24, 2006 2:10 pm
by slappy434
Alright, I'm glad I posted on here. you all provide good reasurance and great advice. We didn't go with that one, especially after I read the last 3 posts....and I'm glad we didn't. She ended up getting an '03 base instead, less miles, side airbags, much much smoother shifting. Dude...I can't thank you guys enough. I've gotten more than I expected from here. This board is mad informative and I'll definately stop back by for good reading.To everyone who's posted in response: I send my best. And she (and I) love the one she has. It is a great driving vehicle and damn versitile at that. I feel a whole lot better about the new one than the other one. After hearing everyones opinion's and doing a little research on transmissions it's definatley best not to have bought the GT....even if it is significantly quicker. Very valuable resources on here and I know I'll be back for more info. So for those of you who've contributed, both of us are much appreciative. We look forward to owning this vehicle. Again, to all: Thanks-D
Re: (slappy434)
Posted: Sat Jun 24, 2006 2:28 pm
by ColonelPanic
Congratulations! It sounds like you guys made the right choice. I'm happy to hear the news. Welcome to the family, hope to see you both around. And I'm sure you'll be asked by many to share some pictures.
Posted: Thu Apr 29, 2010 4:23 pm
by BlackBear
I just found this thread and I also drive an 03 GT VIBE AND HAVE THE EXACT SAME PROBLEM. Problem is I own the car and don't have a whole lot of money to spend on fixing or installing a new transmission. What would be the best way to go about this? The shift grind has always grinded into 2nd and 3rd, and I've been driving this car for 2 years. It's got about 130,000 miles on it. thinking about trying Jahntassa's method, but would this really help the synchro mesh problem?
Re: (BlackBear)
Posted: Thu Apr 29, 2010 4:43 pm
by star_deceiver
Try changing to a heavier full synth tranny fluid like an 80w-140 or some redline shockproof gear oil (red bottle).
