speakers
Posted: Tue Jun 20, 2006 4:44 am
by melders
what kind of speakers do you all recommend for my vibe? i am not looking to spend to terribly much, but i really want to get rid of the stock speakers. how big do they have to be?thanks
Re: speakers (melders)
Posted: Tue Jun 20, 2006 5:52 am
by miked
I've got some Boston Acooustic, S-65. They're pretty descent for the price, you can probably find them at 60U$ on ebay.Mike
Re: speakers (miked)
Posted: Tue Jun 20, 2006 6:29 am
by Mrizzle05
ive seen the speakers on the vibe....but question. what are teh front and rear sizes for the stock speakers?Thanks
Re: speakers (Mrizzle05)
Posted: Tue Jun 20, 2006 6:44 am
by SeattleJeremy
Quote, originally posted by Mrizzle05 » what are teh front and rear sizes for the stock speakers?I need to know too
Posted: Tue Jun 20, 2006 6:45 am
by KaosStarr
I believe the front and the rear are both 6.5s. The fronts will also need a 1" spacer to clear the window.
Re: (KaosStarr)
Posted: Tue Jun 20, 2006 6:57 am
by nygiantzz1
You are right. 6.5" speakers in both front and rear doors. Source: Crutchfield.com Crutchfield advised that speaker brackets are necessary for proper installation.
Re: (nygiantzz1)
Posted: Tue Jun 20, 2006 7:01 am
by Mrizzle05
ok cool. thanks
Posted: Tue Jun 20, 2006 11:56 am
by meistees
i put 6.5 inch in the front and back.. in the back door I used the speaker bracket that came from Crutchfield but in the front I used a post from the site and cut out the speaker cone from the stock front speakers and used a dremel tool to cut the plastic ribs holding the magnet in with some other minor modifications mounted the aftermarket speaker in the remaining stock speaker frame ..worked great
Re: (meistees)
Posted: Wed Jun 21, 2006 2:05 am
by NascarXprt
thats what i did to the front speaker but i just took out the rear speaker assembly and put the new speaker in the door no braket needed.heres what the front looks like
Re: (NascarXprt)
Posted: Wed Jun 21, 2006 7:02 am
by Mrizzle05
my buddy can get me cheap speakers... but they make them 6.75"would they still work as far as fitment on the stock location
Re: (Mrizzle05)
Posted: Wed Jun 21, 2006 8:25 am
by nygiantzz1
I checked Crutchfield for you and a 6 3/4" speaker will fit. I copied the following from the website: Installation Details for your 2005 Vibe » Use the factory speaker grilles. » A speaker adapter bracket is required. It is included free with your speaker purchase. » Re-drill the mounting screw holes. » Drill out rivets to remove the factory speakers. Most of the speakers listed were 6 3/4" but will fit the 6 1/2" opening. Maybe your buddy can help you with the brackets needed or you might be able to modify the factory bracket like meistees did.
Re: (nygiantzz1)
Posted: Wed Jun 21, 2006 8:28 am
by Mrizzle05
ok cool. ill look into that.thanks
Posted: Mon Jul 10, 2006 8:57 pm
by RationPack
Thanks for your speakers pictures, NascarXprt Very helpfull
