ac drip
Posted: Mon Jun 19, 2006 10:33 pm
by melders
hey guys, first of all i am new to this forum. i just bought an 03 vibe last week. i love it, but it has one problem, the AC Drips Inside the car, instead of outside. the dealer said they would take care of it, but i wondered if i could do it myself. i removed the drain, and made sure it was clear of any debris, and it was. so does anyone else know what might be causing this? i cannot use my AC, but if i do, it drips into the car on the passenger side, causing it to get all wet. any help would be nicethanks again!
Re: ac drip (melders)
Posted: Mon Jun 19, 2006 10:42 pm
There's a thread here somewhere about the drain hose falling off and causing that problem, but you said you checked that, so I don't know.you should try to do is make it to the grand mega meet in Fenton MI this Saturday.
Posted: Mon Jun 19, 2006 10:45 pm
by Baltovibe
Posted: Tue Jun 20, 2006 12:19 am
by ToolGuy
And do not use anything too tight, you do not want to crack the tubing! I used a normal zip tie...
Posted: Tue Jun 20, 2006 12:29 am
by melders
i just took a look at it, and everything seemed to be hooked up, and clear...any other ideas? or should i try again, and see if it gets wet again?
Posted: Tue Jun 20, 2006 12:37 am
by ToolGuy
Did you remove the rubber hose and make sure it was clear?Sounds like you did but I still had to ask...
Re: ac drip (MiVibe-ToolGuy)
Posted: Tue Jun 20, 2006 12:42 am
by ToolGuy
The GM service manuals state this... It is under ODOR but see my hightlighted text...Odor DiagnosisStep Action Yes No 1 Sit inside the vehicle. Close all of the doors and windows. Start the engine. Allow the engine idle at normal operating temperature. Select the maximum blower speed. Select the panel air outlet mode. Select the coldest temperature setting. Cycle through all of the blower speeds, modes and temperatures to define what type of odor is present. - Musty smell - Coolant smell - Oil smell Does the odor have a musty smell? Go to Step 2 Go to Step 8 2 Inspect the HVAC filter for debris.Is the HVAC filter clean of debris? Go to Step 3 Go to Step 4 3 Inspect the passenger compartment filter for odor. If the filter has an odor, replace the filter. Did you replace the filter? Go to Step 16 Go to Step 5 4 Remove any debris from the filter.Is the action complete? Go to Step 16 -- 5 Inspect for wet carpeting. Is the carpet wet? Go to Step 6 Go to Step 15 6 Inspect for the following conditions: • Water leaks around the windshield • Blockage of the HVAC module drain • Leaks around the door seals • Blockage of the plenum drain Is a leak present? Go to Step 7 Go to Step 15 7 Repair the leak as necessary.Is the repair complete? Go to Step 16 Go to Step 8
Posted: Tue Jun 20, 2006 12:49 am
by melders
Quote, originally posted by MiVibe-ToolGuy » • Blockage of the plenum draini know for sure that it is the AC, what is the plenum drain?the reason i know for sure it is the ac, is because i washed it last night, and it was dry.
Posted: Tue Jun 20, 2006 12:56 am
by ToolGuy
Yep I believe you it is AC and not water leak...Got me on the plenum... It might be related to the Evaporator Core since that is inside the car and sweats when the AC is on, thus drains to the hose...I looked in the service manuals and did not find that so it must be related to another part (my best guess).Or something may be cracked or a seal is bad letting the water in instead of draining it properly.
Posted: Tue Jun 20, 2006 2:34 am
by melders
well, after driving it for lunch it did not drip (i had ac on full). i was driving for about 20-30 mins and the ac was on the whole time...so no leak as of now...i am not going to say that it is solved yet, i have to do some more driving to figure out whether or not it is fixed...if anyone has any more ideas, please let me know....thanks to all that have helped
Posted: Tue Jun 20, 2006 3:06 am
Maybe you fixed it by reseating the drain hose.( and maybe the plenum is the cabin air intake between the windshield and the hood? )
Re: ac drip
Posted: Mon Sep 18, 2006 11:14 am
by Bectech
In just the last 3 days I'm seeing this ac drip problem in my Vibe. I checked the drainage hose and it is hooked up fine. If I have the a/c on I hear a hissing sound for about 5 seconds. This happens about once every 5 minutes. I believe this is when the water is getting sprayed on the front passenger side. Today I noticed that I'm getting water on the front drivers side also, though not as much. Any ideas ? It started on Sat when my wife had her bag shoved up underneath the dash on the passenger side. It may be just a coincidence though, because I don't see anything wrong under there.Bec
Posted: Mon Sep 18, 2006 1:01 pm
by zionzr2
for those checking that the hose is securly atached you may also want to check that its not blocked or plugged up anywhere either. this too could cause the dripping and wet interiors.
Re: ac drip (Bectech)
Posted: Mon Sep 18, 2006 9:24 pm
by ToolGuy
Quote, originally posted by Bectech » In just the last 3 days I'm seeing this ac drip problem in my Vibe. I checked the drainage hose and it is hooked up fine. If I have the a/c on I hear a hissing sound for about 5 seconds. This happens about once every 5 minutes. I believe this is when the water is getting sprayed on the front passenger side. Today I noticed that I'm getting water on the front drivers side also, though not as much. Any ideas ? It started on Sat when my wife had her bag shoved up underneath the dash on the passenger side. It may be just a coincidence though, because I don't see anything wrong under there.BecOnly when the AC is on?Not sure what else to recommend, if you looked at the service manual steps I posted above.
Posted: Tue Sep 19, 2006 8:01 am
by melders
make sure its not pluged or soemthing....i thought i had the problem, but it was just off, and i also had a leak in the car..that is fixed though
Posted: Tue Sep 19, 2006 6:43 pm
by Bectech
good call, MikeI tried again to get that drainage tube off but that little (removed) is on there pretty snug ! (though I suppose that's better than having it slip off on its own like other people have had a problem with) Anyway, I stuck a screwdriver up the tube and got a few drops of water. I tried again, this time turning the screwdriver a little and WHOOSH!!! water started pouring out ! Good thing I had thought to bring a container with me so I could catch the water. I estimate there was almost a quart of water that came out of there !!I never did see any kind of debris so I'm not really sure what was causing the clog but I ran the A/C while driving today (over an hour of driving) and so far there's no water leaking out on my carpet. Hopefully it's fixed now and not just filling up the chamber again. (nice cynical attitude, eh ?) Bec
Posted: Tue Sep 19, 2006 8:23 pm
by KNINE
Try penicillin. It cures most drips.
Posted: Tue Sep 19, 2006 11:41 pm
by scherry2
the plenum drain:under the cowl where your windsheild wiper motor is, is the plenum it goes from one side of the car to another as the top of the firewall (flat metal piece) it covers the fresh air vent for the A/C and on the end by the fenders is a hole where the water drains out from rain water running down the windsheild on to the cowl.
