loose bolts
Posted: Wed Jun 14, 2006 3:54 am
by vintagegz
Just a heads up, was checking my month old Vibe for rattles on the weekend, found three of the four door latch mechanisms were loose ( they use 3 torx screws to attatch them) and of the 4 bolts holding the hood to the hinges, one bolt was missing, the hole was stripped. Amazing how these things get through quality audit!
Re: loose bolts (vintagegz)
Posted: Thu Jul 06, 2006 6:05 am
That sure isn't right.You shouldn't have to but it should be easy enough to tighten up the loose ones. The missing bolt and stripped hole though, you need to make the dealer make it right
