Location of sub-woofer installment
Posted: Wed Jan 22, 2003 4:57 pm
by Vibe-agra
Some owners have added a sub-woofer to their stereo to upgrade the base. Where would be a good location to install it?
Re: Location of sub-woofer installment (The Vibrator)
Posted: Wed Jan 22, 2003 10:55 pm
by Sub-Vibe-R
I put mine in the trunk. Wiring pass under the platic at the bottom of the doors, then under the rear seat and come out in the trunk from the existing hole for child seat. I drilled only 1 hole, in the platic between the rear seat and the trunk.
Re: Location of sub-woofer installment (Sub-Vibe-R)
Posted: Fri Jan 24, 2003 11:03 am
by ourvibe
I installed a JL audio microsub in rear hatch area. Sub was mounted using JL supplied mounting bracket to the vibe track system. I can still open cover over spare without removing sub. Wiring was run under carpet from amp under passenger seat. No holes drilled. Sounds great and takes up little room.
Re: Location of sub-woofer installment (ourvibe)
Posted: Wed Jan 29, 2003 10:07 pm
by Sub-Vibe-R
Take a look to my topic. You'll see all my installationhttp://forums.genvibe.com/zerothread?id=2524
Posted: Thu Jan 30, 2003 4:13 am
by NY Pete
You gonna clean that up bit when it gets warmer? all those exposed wires going to the amp, amp mounted to the box... messy messy IMHO...
Re: Location of sub-woofer installment (NY Pete)
Posted: Thu Jan 30, 2003 5:01 am
by Sub-Vibe-R
quote:You gonna clean that up bit when it gets warmer? all those exposed wires going to the amp, amp mounted to the box... messy messy IMHO...Messy but easy to remove when more space is needed. 3 screw, 2 RCA and pop, no more sub.
Posted: Thu Jan 30, 2003 6:06 am
by NY Pete
Oh you made it so you can remove it. MY bad.
