Gear Ratios for Manual Transmissions?
Posted: Wed Jun 07, 2006 3:50 pm
by SeattleJeremy
I found the Gear Ratios for the Automatic's in this thread.http://forums.genvibe.com/zerothread?id=4234I was wondering what they are for the manuals. Also, how difficult is it to change out teh 5speed for the 6?
Re: Gear Ratios for Manual Transmissions? (Jeremy96gase)
Posted: Wed Jun 07, 2006 7:38 pm
http://forums.genvibe.com/zero...09054Quote, originally posted by NovaResource2 »5th gear in the 6-speed is also overdriven (overdrive is a gear ratio that is less than 1.00):1st : 3.172nd : 2.053rd : 1.484th : 1.175th : 0.92 (overdrive)6th : 0.73 (overdrive)Reverse : 3.25Final Drive Ratio: 4.53 BTW, the 5-speed also has 2 overdrive gears:1st : 3.172nd : 1.903rd : 1.314th : 0.89 (overdrive)5th : 0.73 (overdrive)Reverse : 3.25Final Drive Ratio: 3.94edit 6/21/2008 - from http://forums.genvibe.com/zerothread?id=4234Quote, originally posted by NovaResource »Auto (FWD):1st : 4.012nd : 2.213rd : 1.434th : 0.98Reverse : 3.27Final Drive Ratio: 2.96Auto (AWD)1st : 2.852nd : 1.553rd : 1.004th : 0.70Reverse : 2.34Final Drive Ratio: 4.24edit 11/20/2006the thread I referenced above was a good reference, and was deleted, I am assuming when the racing forum was converted to "The Track" but I found it in google cache, so I'm pasting it in here so the information and discussion is still part of the forumQuote, originally posted by GenVibe thread 9053" »This is G o o g l e's cache of http://forums.genvibe.com/zero...age=1 as retrieved on Mar 31, 2006 09:25:23 GMT. Hit lift in 6th?First 1 2 > LastAuthor PostdrummerdudeMemberOffline500 postsWaxahachie TXJoined 12-4-2003 Hit lift in 6th?« » 2:44 PM 3/18/2004 Reply Edithas anyone hit lift in 6th yet? i've been to 130 mph around 7-7500 rpm's in fifth and i'm wondering if anyone has shifted into 6th and still been in lift. just wondering if you have kind of torque and accelleration in 6th. thanks to all who post.03 Abyss GT, Cosmo Racing CAI, Eibach Sportline, 17" OEM Wheels,SS h4 & 9006Soon to come: Wheels, body kit, & Turbo from StaffordRecent Kills: Dakota R/T, Tibouron V6, Ram 3500 cummins turbo, Acura Integra, Ford Focus zxt with "Mach" badging, a Mitsubishi Diamante, numerous f-150's and silverado (all the hicks in tx think that they're trucks with 33"swampers are still fast)==================================================================================Salsa!MemberOffline0 postsJoined 6-11-2002 Re: Hit lift in 6th? (drummerdude)« » 3:06 PM 3/18/2004 Reply EditI don't have a GT but it can be possible at high speeds (very high speeds) to hit lift in 6th gear, but the reaction would be alot different than in lower gears since this is an overdriven gear...===================================================================================Sub-Vibe-RGenVibe GodOffline2591 postsSt Constant QcJoined 8-27-2002 Re: Hit lift in 6th? (Salsa!)« » 3:49 PM 3/18/2004 Reply EditI agree with Salsa. As the 6th gear or nothing but an overdrive, hitting lift in this gear will not be as noticable then in other gears.===================================================================================drunkenvibeGenVibe GodOffline5451 postssmelly city by St. Louis ILJoined 7-21-2003 Re: Hit lift in 6th? (Sub-Vibe-R)« » 4:33 PM 3/18/2004 Reply Editi don't think the car will let you go fast enoughRIP D.D. your BS will be missed.===================================================================================savedbyzeroGenVibe GodOffline1064 postsFairfax VAJoined 4-15-2002 Re: Hit lift in 6th? (drunkenvibe)« » 6:59 PM 3/18/2004 Reply EditYou will actually pull faster speeds in a quicker amount of time in fifth. Like was said before, sixth is an overdrive gear.Booze, Broads, and Hot Rods===================================================================================NovaResource2MemberOffline172 postsCyberspaceJoined 1-19-2004 Re: Hit lift in 6th? (savedbyzero)« » 10:22 PM 3/18/2004 Reply Edit5th gear in the 6-speed is also overdriven (overdrive is a gear ratio that is less than 1.00):1st : 3.172nd : 2.053rd : 1.484th : 1.175th : 0.92 (overdrive)6th : 0.73 (overdrive)Reverse : 3.25Final Drive Ratio: 4.53BTW, the 5-speed also has 2 overdrive gears:1st : 3.172nd : 1.903rd : 1.314th : 0.89 (overdrive)5th : 0.73 (overdrive)Reverse : 3.25Final Drive Ratio: 3.94===================================================================================dmitriMemberOffline729 postseast hanover njJoined 4-25-2003 Re: Hit lift in 6th? (NovaResource2)« » 1:12 AM 3/19/2004 Reply Editive tried numerous times and cant, impossible.===================================================================================JahntassaGenVibe GodOnline2635 postsConyers GAJoined 7-9-2003 Re: Hit lift in 6th? (dmitri)« » 8:35 AM 3/19/2004 Reply EditQuote, originally posted by dmitri »ive tried numerous times and cant, impossible.Physically impossible, or just can't be done because of a speed limiter?I would have to wonder if there's something in the ECU that would block out lift in 6th, but I don't think the ECU is aware of what gear you're in..2003 Vibe GT Lava"He inched his way up the corridor as if he would rather be yarding his way down it.""For a moment, nothing happened. Then, after a second or so, nothing continued to happen." - Douglas Adams...we all miss you===================================================================================robdogMemberOffline427 postsSomewhere PAJoined 12-30-2002 Re: Hit lift in 6th? (Jahntassa)« » 3:15 PM 3/19/2004 Reply EditI believe drag limitations will pevent you going fast enough in 6th to engage lift, 129 is about as fast as you can go in a GT. Speedo may say faster but it is not accurate at those speedsAbyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.===================================================================================MadBillGenVibe GodOffline1624 postsPeterborough OntarioJoined 11-14-2002 Re: Hit lift in 6th? (robdog)« » 7:33 PM 3/19/2004 Reply EditI'm with Robdog on this. If you use the data provided above by Nova: 6,000RPM in6th is 6000/0.73/4.53 = 1814.3 wheel RPM. With a diameter of 24.9" (perTire Rack's data page), the circumference is 24.9 x 3.1416 = 78.2", so thecar will travel 1814 x 78.2 inches in one minute. Divide by 63,360 for miles= 2.24 miles per minute or 2.24 x 60 miles in anhour = 134.4 MPH.So, assuming there is no speed limiter, one would have to reach a true 135MPH to hit lift. Keeping in mind that the 2ZZ puts out only (Damn! Where's a dyno trace when you want one?) maybe 125-130 wheel HP @ 6,000 RPM before lift, it would seem you'd need one humongous downhillto make it happen!===================================================================================Kissfan79MemberOffline323 postsHonolulu HIJoined 3-14-2003 Re: Hit lift in 6th? (MadBill)« » 11:37 PM 3/20/2004 Reply EditOk....how about this one: Say for instance that you're in your GT and yo
u are flying along and do hit that long downhill and gun it. You from 5th into 6th and say you actually creep your way into lift in 6th gear. You would already be doing 135ish. How much further do you think she will go now that the car is in lift and has the extra horsepower for another 2000 rpms? Just curiousJimAbyss Vibe GT monotoneMoon & Tunes w/6 disc changerCargo nets and mat93 Octane w/ lots o' KISS in the CD changer===================================================================================MadBillGenVibe GodOffline1624 postsPeterborough OntarioJoined 11-14-2002 Re: Hit lift in 6th? (Kissfan79)« » 7:21 AM 3/21/2004 Reply EditThe power required to overcome drag increases as the cube of the speed. Would have to look at a dyno curve, but if you had just enough power to hit lift on a downgrade and if lift added 10 HP at that RPM, it would take you from say 130 to 140 HP = 1.077. The cube root of that is 1.025, so your new top speed would be 135 x 1.025 = 138.4 MPH.===================================================================================Kissfan79MemberOffline323 postsHonolulu HIJoined 3-14-2003 Re: Hit lift in 6th? (MadBill)« » 9:52 AM 3/21/2004 Reply EditIf memory serves me correct, someone here had a dyno done on thier GT and it reported 153 to the wheels. Hmmmm....interesting.JimAbyss Vibe GT monotoneMoon & Tunes w/6 disc changerCargo nets and mat93 Octane w/ lots o' KISS in the CD changer===================================================================================Stang2VibeModeratorOffline3801 postsPittsburgh PAJoined 10-31-2002 Re: Hit lift in 6th? (Kissfan79)« » 11:44 PM 3/21/2004 Reply EditThat sounds possibly like peak wheel HP in stock form.From all accounts that I've seen, the GT is not electronically limited so it is drag limited (at 129 MPH on a flat surface as previously noted). MadBill's calculations would probably answer everything the best.MadBill, you calculated for lift beginning at 6,000 RPM, but I think the actual point when lift will engage is 6,250 RPM, so it would be even harder to hit lift in 6th gear. It would have to be like a decent to the bottom of hell to be able to accomplish this. As you said, it requires exponentially more force per unit to accelerate the vehile as velocity increases. So even if you did get 'er rolling downhill fast enough to hit lift in 6th, the forces acting against you would be so great that you probably would not even feel the acceleration. I wouldn't want to take a GT in stock form that fast anyway, the thing would be so unstable at that high of a speed and I doubt that the tires are rated for speeds that high as well.02/14 can go take a flying leap right off the calendar.===================================================================================ALi3NMemberOffline173 postsHouston TexasJoined 11-17-2003 Re: Hit lift in 6th? (Stang2Vibe)« » 4:03 AM 3/22/2004 Reply EditI'm sorry guys, i think that none of you are giving the speedo enough credit. I would agree that it is not 100% accurate, but there is no way it would be off more than +/- 3 mph...unless you had a front tire that was half flat or you were airborne. I have to agree on the 6th overdrive thing. I can get the car up to much higher speeds if i just let the car tach out in 5th rather than trying to accelerate in 6th in the triples. On my way back from vacation yesterday i got a really straight flat stretch of empty road and hit 139 mph (+/- 3) in 5th. If i remmber correctly i was at about 7k on the tach and still had a little throttle left under my foot. The car just does not seem to have the torque required to do much in 6th. ...and if this car does have an electronic limiter it is set way higher than i will ever go.Am i the only one that has made the speedo read 139?ALi3N aka Dj ViP3RThere is a force through the euphoric beat causing uncontrolablemovement of your body, I am that force. Take a journey beyond the limits of your mind.'Download Mixes:http://shlrm.org/DjViP3R/http://www.mys ... ip3rLatest Mixes: 'Nightlife' & 'M0Ti0N -X-'Pimpin' Abyss Vibe GT w/ Nav===================================================================================Kissfan79MemberOffline323 postsHonolulu HIJoined 3-14-2003 Re: Hit lift in 6th? (ALi3N)« » 12:04 PM 3/22/2004 Reply EditI was just thinking about the lift in 6th thing just as an idea if it were indeed possible. I would never want to go that fast in 6th. I would, just as you said, stay in 5th. There is no electronic limiter. The car is drag limited. If someone had a CAI and say a magnaflow exhaust where their HP was pushing 200 at the flywheel vs the stock 180. I would think that there would be no problem with the car going past the stock 129 drag limit. The fastest I have gone was 110 (and she was nicely stable I must add).JimAbyss Vibe GT monotoneMoon & Tunes w/6 disc changerCargo nets and mat93 Octane w/ lots o' KISS in the CD changer===================================================================================drummerdudeMemberOffline500 postsWaxahachie TXJoined 12-4-2003 Re: Hit lift in 6th? (Kissfan79)« » 2:03 PM 3/22/2004 Reply Editi had my speedo reading 130 the other night, no problems... no rattling, vibrations in the wheel, and i was still climbing in fifth. once i get my trubo from stafford i'll let you know if its possible to hit lift in sixth. i'm sure it will be possible when my whp is somewhere near 300!!! ahhhh i can't wait! (of course i will need a new drivetrain but its all good!)03 Abyss GT, Cosmo Racing CAI, Eibach Sportline, 17" OEM Wheels,SS h4 & 9006Soon to come: Wheels, body kit, & Turbo from StaffordRecent Kills: Dakota R/T, Tibouron V6, Ram 3500 cummins turbo, Acura Integra, Ford Focus zxt with "Mach" badging, a Mitsubishi Diamante, numerous f-150's and silverado (all the hicks in tx think that they're trucks with 33"swampers are still fast)===================================================================================trdvibeGenVibe GodOffline8672 postsgoodbye vibe gt 4.20.05Joined 4-24-2003 Re: Hit lift in 6th? (drummerdude)« » 2:05 PM 3/22/2004 Reply Editare you going to get that turbo then? if so, let me know how it all goes. maybe later down the road i'll be able to afford it...2005 Subaru Legacy GT Limited SedanComing Soon: Stage 2 Cobb Access PortTRDvibe (former 2003 Pontiac Vibe GT)===================================================================================drummerdudeMemberOffline500 postsWaxahachie TXJoined 12-4-2003 Re: Hit lift in 6th? (trdvibe)« » 2:13 PM 3/22/2004 Reply Editit'll be at least 4-6 months before i get it... i'm going to let the warranty go before i install it. and i think i'm actually going to drive to Ca to have them install it themselves. and let them dyno it for me. i'll keep you posted03 Abyss GT, Cosmo Racing CAI, Eibach Sportline, 17" OEM Wheels,SS h4 & 9006Soon to come: Wheels, body kit, & Turbo from StaffordRecent Kills: Dakota R/T, Tibouron V6, Ram 3500 cummins turbo, Acura Integra, Ford Focus zxt with "Mach" badging, a Mitsubishi Diamante, numerous f-150's and silverado (all the hicks in tx think that they're trucks with 33"swampers are still fast)trdvibeGenVibe GodOffline8672 postsgoodbye vibe gt 4.20.05Joined 4-24-2003 Re: Hit lift in 6th? (drummerdude)« » 2:18 PM 3/22/2004 Reply Editya, i don't blame you. i'd want them to install it too. would be a very fun road trip there to see the diff when you drive back!2005 Subaru Legacy GT Limited SedanComing Soon: Stage 2 Cobb Acce
ss PortTRDvibe (former 2003 Pontiac Vibe GT)===================================================================================joatmonGenVibe GodOffline5561 postsSMC MDJoined 3-21-2003 Re: Hit lift in 6th? (NovaResource and MadBill)« » 12:34 AM 5/16/2004 Reply EditNova, MadBIll,wondering about gear ratios and such, extrapolating from your posts,6000 rpms in 6th gear = 134.4 mph, then 3000 rpms in 6th gear = 67.2 mphsince 5th in the 5 speed is the same gear ratio as 6th in the GT, but the 5 speed final drive is 3.94 where the 6 speed final drive is 4.53, then 3000 rpm in 5th gear in a 5 speed is 67.2 * 4.53 / 3.94, or 77.2 mph?What does that mean? In the highest gear at the same vehicle speed, a GT engine is at a higher RPM than a base? If I put a 6 seed tranny in a base, would that give the base more torque? If I put a 5 speed in a GT, would that give it better mpgs?I am not going to do either, jsut curious. Also, where is the "final drive"? Is it integral to the transmission, or is it a seperate piece (like the rear in a RWD car)?===================================================================================MadBillGenVibe GodOffline1624 postsPeterborough OntarioJoined 11-14-2002 Re: Hit lift in 6th? (joatmon)« » 7:57 PM 5/16/2004 Reply EditQuote, originally posted by joatmon »Nova, MadBIll,wondering about gear ratios and such, extrapolating from your posts,6000 rpms in 6th gear = 134.4 mph, then 3000 rpms in 6th gear = 67.2 mphsince 5th in the 5 speed is the same gear ratio as 6th in the GT, but the 5 speed final drive is 3.94 where the 6 speed final drive is 4.53, then 3000 rpm in 5th gear in a 5 speed is 67.2 * 4.53 / 3.94, or 77.2 mph?What does that mean? In the highest gear at the same vehicle speed, a GT engine is at a higher RPM than a base? If I put a 6 seed tranny in a base, would that give the base more torque? If I put a 5 speed in a GT, would that give it better mpgs?I am not going to do either, jsut curious. Also, where is the "final drive"? Is it integral to the transmission, or is it a seperate piece (like the rear in a RWD car)?Hi joatmon.Yes, the 6 speed would give a base Vibe better acceleration, and the 5 speed would help economy on the GT (but I expect its acceleration would suffer more than any gain on a base, due to the "peaky" powerband of the GT and the bigger RPM drops on the shifts with the 5 speed.)BTW, the base does feel like it's geared tall for economy. Mine indicates just over 120 KPH (~75 MPH) @ 3,000. I can hit ~93 MPH in 3rd gear, and can't pull some medium hills in 5th without losing 10 MPH...===================================================================================futseal04MemberOffline346 postsMoore OKJoined 5-24-2004 Re: Hit lift in 6th? (MadBill)« » 1:59 PM 5/27/2004 Reply EditThe 6 speed would help the base get better acceleration, due to the fact that the ratios are closer, and therefore keep the engine in it's powerband. The GT would get the same fuel economy with either tranny, since the ratios in the top gears are the same. The reason it doesn't is beacuse the final drive (or in RWD cars "axle ratio") is lower (numerically higher). If the GT had the same gears (3.94) as the base, it would get better gas mileage, but acceleration would suffer due to not being in the upper part of the rev range under WOT (or out of lift). The GT has this ratio due to the fact that most of the power lies above 6k, and 4 bangers as a whole have lower final drive ratios. V-8's usually come with anything from a 3.27 (Mustangs) to a 3.43(LS1/LT1 Chevy's). Overdrive for the 6 speed in those cars are a .5, and that is why they only turn about 1200 at 60 in 6th.'04 Vibe Base'97 Buick Riviera S/C'01 Suzuki SV650S===================================================================================goodvibeMemberOffline811 postschicago ILJoined 7-28-2003 Re: Hit lift in 6th? (futseal04)« » 10:13 PM 5/27/2004 Reply EditEven if you could get it up to lift speed for the shift to 6th, you fall out of lift and slow down a lot. There isn't enough hp low in the lift range to overcome the drag at that speed or any that would equal lift in 6th.Vibe GT, TRD springs, Progress bar, STB, Unichip, Borbet E 16x7.5, 225/50 Bridgestone RE750, beefed up grounds and battery bypass capacitors(had em laying around)===================================================================================Smokin' RubberMemberOffline664 postsSeattle WAJoined 4-3-2003 Re: Hit lift in 6th? (goodvibe)« » 6:00 AM 5/29/2004 Reply EditStafford makes a turbo (300 some hp you say?) for the Vibe (GT i assume)? Hmmm interesting, wonder how much better it is than the XS Engineering Turbo kit (250 whp supposedly and completely safe for the already high compression) I was thinking of getting the XS engineering kit but if the stafford one is better I might just get that.Man I can just here the sweet sound of the blow off valves between shifts. *vroooooom* *spooosh* *vrooooom*===================================================================================Smokin' RubberMemberOffline664 postsSeattle WAJoined 4-3-2003 Re: Hit lift in 6th? (Smokin' Rubber)« » 12:14 PM 5/31/2004 Reply EditOk I checked and basically the two turbo kits are mostly identical you get a bit more power out of the XS engineering kit (btw this is for the 2zz so you need to look at the Celica GTS turbo kits). The description is kind of misleading, it says the Garret turbo can get up to 350 whp out of it but for the celica they only got out 240 so don't be expecting 300 hp if you buy the turbo kit===================================================================================marlborocowboy82MemberOffline73 postskansas city moJoined 6-7-2004 Re: Hit lift in 6th? (robdog)« » 6:24 PM 6/8/2004 Reply Edit134 is the top speed i the 03 gtbeen there lots===================================================================================EvanshallMemberOffline207 postsEnouph PlaceJoined 6-13-2004 « » 10:27 PM 6/15/2004 Reply Editheres my qeustion, how should we lower the Drag, if you lowered it and got a body kit would that do it?? i mean i know theres limitations, but...?im not much a fan of body kits i wish someone would get like a 2.5 or 3.5 lowering kit out there, get it as low as it can go without scrapping the ground everytime it hit the speedbump, as practically low as posssible really===================================================================================MadBillGenVibe GodOffline1624 postsPeterborough OntarioJoined 11-14-2002 Re: (Evanshall)« » 11:23 PM 6/15/2004 Reply EditIt's hard to make a large difference but yes, lowering will help and a body kit might, but it's a safe bet that the designers never actually checked the drag. Other factors include removing the roof rack crossbars (if not the whole rack),closing in as much of the grill as possible without causing overheating, building a vey low front spoiler under the nose to keep the turbulent airflow out from under the car, running mfgrs. max specified tire pressure to reduce rolling resistance, making sure toe-in is near zero, ensuring no brake drag, etc.Given a straight and level deserted road, it's easy to check the effect of various factors re drag. You just accelerate up to a fast but safe speed, pop it in neutral and time the interval to coast down to say a 20 MPH lower speed. Repeat several times in each direction, toss out any obvious outlying results and average the rest. Then change something and compare results. I tweaked a front spolier for my Metro this way to get best results and gained 2 MPG.===================================================================================futseal04MemberOffline
346 postsMoore OKJoined 5-24-2004 Re: (Evanshall)« » 12:15 PM 6/16/2004 Reply EditBody kits, will on average, increase drag by raising the amount of frontal area. This is true for any add-on, but some kits have been tuned to provide downforce at speed, at the expense of added drag.Remember that to double speed, you have to cube power (all other things constant). For example, if you need 200HP to hit 100MPH, you would need 800HP to hit 200MPH.'04 Vibe Base'97 Buick Riviera S/C'01 Suzuki SV650S===================================================================================Smokin' RubberMemberOffline664 postsSeattle WAJoined 4-3-2003 Re: (futseal04)« » 3:07 AM 6/17/2004 Reply EditActually some body kits actually do reduce drag. By having spliters they divert the air away from underneath the car and the wheels. Even if there is more surface area to push against usually it is more aerodynamic than the underside of your car. If boyd kits were pointless and only increase drag then why would almost everything single super high end car (ferrari, mclaren, etc) have one?===================================================================================futseal04MemberOffline346 postsMoore OKJoined 5-24-2004 Re: (Smokin' Rubber)« » 2:00 PM 6/17/2004 Reply EditQuote, originally posted by Smokin' Rubber »If boyd kits were pointless and only increase drag then why would almost everything single super high end car (ferrari, mclaren, etc) have one?Because they are designed with it from the start.....not just added on as an afterthought.Plus, a lot of super high-end cars are designed with flat undersides to alleviate drag. Then they use small spoilers to generate downforce at speed. Notice how no high speed cars have really tall spoilers or overexaggerated bodywork like ricers do. The cars that you mention have all of this incorporated into the design of the car.'04 Vibe Base'97 Buick Riviera S/C'01 Suzuki SV650S===================================================================================Smokin' RubberMemberOffline664 postsSeattle WAJoined 4-3-2003 Re: (futseal04)« » 5:30 PM 6/17/2004 Reply EditTrue, but if you think about it they really are bascially the same thing. It just that one already came with a body kit as the bumper where as for many newer body kits you just replace the front bumper with a body kit. And actually you are incorrect about the large spoilers, many high end cars also have fairly large spoilers...===================================================================================futseal04MemberOffline346 postsMoore OKJoined 5-24-2004 Re: (Smokin' Rubber)« » 11:31 PM 6/17/2004 Reply EditThose boyd kits are for downforce. Since those cars don't hit speeds high enough (relatively) for drag to become a big factor, they have those kits which increase downforce at the expense of drag. THey wont go as fast (again relative), but they are glued to the tarmac.'04 Vibe Base'97 Buick Riviera S/C'01 Suzuki SV650S===================================================================================MadBillGenVibe GodOffline1624 postsPeterborough OntarioJoined 11-14-2002 Re: (futseal04)« » 1:49 PM 6/18/2004 Reply Editfutseal is right. On any kind of closed circuit, downforce is far more important than drag, so big wings are the norm (e.g. F1). At the Bonneville salt flats you might see fins for stability, but never wings. Even the Oldsmobile Aerotec, which set the current world's closed-course speed record more than 10 years ago (with a 1,200 HP 2.0 L. Quad 4), had only a very small wing.===================================================================================Smokin' RubberMemberOffline664 postsSeattle WAJoined 4-3-2003 Re: (MadBill)« » 8:53 PM 6/18/2004 Reply Editoh I wasn't debating whether or not the wings would slow the car down, just pointing out that saying "only ricers have enormous spoilers" is not entirely true.===================================================================================EvanshallMemberOffline207 postsEnouph PlaceJoined 6-13-2004 Re: (Smokin' Rubber)« » 12:03 AM 6/24/2004 Reply Editsooo... we ever figure out how fast we would be going at 8400 in 6th yet?? just saying if we had the power to and same drivestrain(hypothetically of course)===================================================================================Emerica13MemberOffline164 postsNovi MIJoined 1-13-2005 « Re: (Evanshall)« » 4:48 PM 4/19/2005 Reply Edit**Hijack**For you guys who were looking at the XS turbo kit, if you bought the celica gts kit, what would you have to do to the engine in the GT to make it fit? I know they are the same engines, but would it be a direct fit, or what other mods would be needed? ThanksEnd hijack2003 Shadow Vibe GT===================================================================================Smokin' RubberMemberOffline664 postsSeattle WAJoined 4-3-2003 « Re: (Emerica13)« » 8:53 PM 4/19/2005 Reply EditYou need different tubing for the engine bay and you need to modify the exhaust manifold I think. There was an article is sport compact i believe where they put the XS kit for the GTS on a Matrix XRS.===================================================================================Emerica13MemberOffline164 postsNovi MIJoined 1-13-2005 « Re: (Smokin' Rubber)« » 4:06 PM 4/20/2005 Reply EditOkay thanks. Also, any idea as to the price of the tubing and other stuff you would need, besides the actual turbo kit?2003 Shadow Vibe GT===================================================================================Smokin' RubberMemberOffline664 postsSeattle WAJoined 4-3-2003 « Re: (Emerica13)« » 5:07 AM 4/25/2005 Reply EditNot a good estimate but I'd guess that stuff would run you quite a bit.... since most of the money for the turbo comes from the piping and the labor it takes to figure out the piping routes and install them. I'd think it would almost be easier to buy the components seperate (turbo, intercooler, BOV, maybe injectors, etc) and then just find a shop to do the piping it will still run you about 3,000 as opposed to 3,000 + changing the piping and such. So really getting it custom do is more cost efficient. I am planning though not sure when to get a custom kit built (and spending the 10,000+ for internals and such) to put out some serious HP. The only thing is I think I'm gonna push it back a year or two (was supposed to get it summer of '06) so I can get an actual job and get done with school so I can actually afford paying the 10 G's.As for the stuff you would need besides the turbo kit it all depends on how much HP you want to make and how much you want to spend. You can add new sleeves, pistons, rods, fuel pump, engine bolts, valves, valve springs, ECU, etc all of which let run higher boost or create more HP.===================================================================================Emerica13MemberOffline164 postsNovi MIJoined 1-13-2005 « Re: (Smokin' Rubber)« » 2:42 PM 4/25/2005 Reply EditThanks a lot! That's what I wanted to know, I'll look into a custom one, even though i won't have that kind of money for years.2003 Shadow Vibe GT===================================================================================joatmonGenVibe GodOffline5572 postsSMC MDJoined 3-21-2003 « Re: Hit lift in 6th?« » 11:12 AM 12/1/2005 Reply EditSeems like lately I keep getting stuck behind people going under the speed limit, and I tend to think of the speed limit as a speed minumum, but anyway,
I was beginiing to wonder if my speedometer was off, perhaps reading low.Quote, originally posted by NovaResource2 »5th gear in the 6-speed is also overdriven (overdrive is a gear ratio that is less than 1.00):1st : 3.172nd : 2.053rd : 1.484th : 1.175th : 0.92 (overdrive)6th : 0.73 (overdrive)Reverse : 3.25Final Drive Ratio: 4.53BTW, the 5-speed also has 2 overdrive gears:1st : 3.172nd : 1.903rd : 1.314th : 0.89 (overdrive)5th : 0.73 (overdrive)Reverse : 3.25Final Drive Ratio: 3.94Quote, originally posted by MadBill »I'm with Robdog on this. If you use the data provided above by Nova: 6,000RPM in6th is 6000/0.73/4.53 = 1814.3 wheel RPM. With a diameter of 24.9" (perTire Rack's data page), the circumference is 24.9 x 3.1416 = 78.2", so thecar will travel 1814 x 78.2 inches in one minute. Divide by 63,360 for miles= 2.24 miles per minute or 2.24 x 60 miles in anhour = 134.4 MPH.soMPH = (RPM/(gear * final drive ratios) ) * ((60* circumference)/63360)if I use MadBill's circumference for standard tire of 78.2, then the equation simplifies toMPH = RPM / (gear ratio * final ratio * 13.5)for my 5 speed, this means that in fourth gear at 3000 rpm, I should be going 3000 / ( 0.89 * 3.94 * 13.5) 63.4 mph and 3000 in fifth gear should be 3000 / (0.73 * 3.94 * 13.5) = 77.3 mphThis morning on the way to work I checked, and my speedometer is hitting these RPM/MPH number pairs right on, or at least close enough that I can't tell the difference. So now I know that there are a lot of slow drivers on the roads around here.would be interesting to see how close other people's manual tranny vibes come to matching the equations.===================================================================================slowvibeMemberOffline34 postslittle rock arJoined 10-4-2005 « Re: Hit lift in 6th? (drummerdude)« » 5:25 PM 12/6/2005 Reply EditHitting lift in 5th gear is tuff enough with the torque we got but it sure is fun, i wondered if anyone was as crazy as me to try and keep up with a 911 GT, my 05 gt is debadged so i got a confused look from the dude at 125 mph and then he siad bye, byeSLOWVIBE05 Vibe GTMoonstone (monotone)Factory XM RadioLeather seatsMoon & Tunes packageTinted windowsCOMING SOON: CAI, Custom graphics, 2 monitor DVD entertainment
Posted: Thu Jun 08, 2006 1:56 am
by SeattleJeremy
I wonder why that didn't come up in my search...Thanks Joatman!Guess I won't be switching to the 6speed in order to get better top gear ratio. Edit: Oh I see now, I only searched in the title.
