Subaru 2007 STi Limited
Posted: Fri Jun 02, 2006 10:52 am
by Mavrik
Quote »SUBARU UNLEASHES IMPREZA® WRX® STI® LIMITED FOR 2007• Less Show, Same Go• Leather Interior, Power Moonroof• Only 800 Numbered Units AvailableNEW YORK, April 13, 2006 – Subaru of America, Inc. today unveiled the 2007 Impreza WRX STI Limited model at the New York International Auto Show. The new edition of the road-conquering Impreza WRX STI packages creates greater comfort and refinement with subtler exterior styling, but does not sacrifice the performance of this street legend.The WRX STI Limited will be available in the fall in a limited run of 800 numbered units, 400 in Satin White Pearl and 400 in Urban Gray Metallic.The 2007 WRX STI Limited delivers all the power and performance of the standard model. This new limited-edition version adds a layer of refinement and design detail enhancements targeted at a new group of driving enthusiasts looking for supercar performance but with an understated demeanor. Designed by Subaru Tecnica International (STI), the high-performance and motorsports subsidiary of Fuji Heavy Industries Ltd., the WRX STI Limited is descended from the Subaru WRC Rally car.“The WRX STI redefined the performance car category when it was introduced in 2004. We know some enthusiasts have resisted the temptation to buy one simply because they want more everyday driving comfort and refinement, along with less aggressive styling,” said Fred Adcock, executive vice president, Subaru of America. “Now, with the STI’s reputation for pure performance unquestioned, we recognized an opportunity to broaden the car’s appeal.”Less Show, Same GoThe 2007 WRX STI Limited stands apart from the standard model with an appearance that’s more low-key, and even stealthy. A new trunk-mounted lip spoiler replaces the standard model’s large dual-plane rear spoiler, and the black aluminum roof vane spoiler is deleted. A new, deep front lip spoiler further distinguishes the WRX STI Limited from the standard model.New Enkei wheels with high-luster paint replace the BBS® wheels, keeping the same 17 x 8-in. size and 225/45 ZR17 Bridgestone Potenza RE070 directional performance tires. Behind the new wheels, black Brembo® brake calipers with white lettering have a more reserved appearance than the gold and red-painted calipers on the standard WRX STI.All WRX STI Limited models feature distinctive black gloss B-pillar paint and high luster paint for the exterior mirrors, and this special edition model includes standard fog lights.New Refined Interior Keeps the Focus on PerformanceThe interior of the 2007 Impreza WRX STI Limited balances the performance-directed design and attitude with a dose of refinement. Most notably, the WRX STI Limited replaces the perforated blue high-grip Alcantara® fabric seating surfaces with leather and new dark gray metallic bezels and interior trim.For the first time in a WRX STI, the performance-design front seats are heated for all-season comfort. Also enhancing all-season driving pleasure, the 2007 WRX STI Limited features the first-ever power glass moonroof on this model. Beyond the changed interior appearance, additional features include new carpeting with improved sound insulation materials, an auto-dimming compass rear view mirror and an audio system input jack for an iPod or other digital music player. Finally, each car in this series gets a sequential number plate.The standard automatic climate control system integrates cabin air filtration. SIRIUS™ Satellite radio availability enhances the versatility of the standard 120-watt AM/FM premium stereo, which includes a 6-disc in-dash CD changer and six speakers.Rally Tested and Road ReadyAll Impreza WRX STI models are powered by a turbocharged and intercooled 2.5-liter DOHC Boxer engine producing 293 horsepower at 6,000 rpm and 290 lb.-ft. of peak torque at 4,400 rpm. The Subaru Active Valve Control System (AVCS) variable valve timing technology helps provide strong torque characteristics throughout the engine’s operating range. A manually operated water spray feature helps to bolster intercooler efficiency during spirited driving.All WRX STI models are exclusively equipped with a 6-speed manual transmission that features carbon-plated double-cone synchronizers on 4th, 5th and 6th gears to help ensure durability.Driver Controlled Center Differential (DCCD) All-Wheel DriveFrom its launch, the WRX STI has been equipped with one of the most advanced and most performance-directed All-Wheel Drive systems on the market, regardless of vehicle segment. The Driver Control Center Differential (DCCD) Symmetrical All-Wheel Drive system uses a planetary-type center differential to provide a 41:59 torque split, with automatic and manual differential modes.Center differential lock-up is controlled by both a mechanical limited-slip type differential and an electronically controlled limited-slip differential. The mechanical limited-slip differential activates and operates initially in response to changes in engine torque, improving overall vehicle stability when accelerating or decelerating. In automatic mode, the electronic limited-slip differential controls the differential lock-up by evaluating the amount of lock-up in the mechanical limited-slip. The total amount of lock-up is based on the combination of both differentials. A steering sensor input improves torque transfer response by more accurately relaying the car’s cornering situation.Set in automatic mode, the DCCD system can vary the torque distribution ratio as needed in response to vehicle acceleration, deceleration, steering angle, cornering force and wheel slippage.In manual mode, DCCD allows the driver to select center differential lock-up to optimize All-Wheel Drive performance for varying driving conditions. The driver first selects manual mode with a console-mounted button and then turns a thumbwheel on the center console to select from among six levels of lock-up. Increasing the locking factor keeps more power at the front wheels (max. 50:50 torque split with 100 percent lock-up selected), which the driver might want in certain driving conditions or on particular road surfaces.A helical-type limited-slip front differential and Torsen® limited-slip rear differential help to optimize power distribution side-to-side, helping to prevent the inside wheels from slipping during cornering.Competition-Bred ChassisA super-stiff Ring Frame Reinforced body structure with a hydroformed front subframe provides the foundation for the high-integrity Impreza platform. Compared to the standard WRX models, the WRX STI models are lowered by 0.4-inch to help lower the center of gravity.The 4-wheel independent suspension inherits its inverted-strut technology from the Impreza WRC competition car. Aluminum front suspension lower control arms and aluminum rear suspension lateral links reduce unsprung vehicle weight. A quick-ratio steering system yields 2.6 turns lock-to-lock, and the steering rack uses a “cannon mount” for greater rigidity that improves on-center response.The powerful Brembo Performance Brake System employs front discs measuring 12.7 inches in diameter and 1.2-inch thick and utilizing 4-piston, fixed-position calipers. The rear discs are 12.3 inches in diameter and 0.8-inch thick and use 2-piston, fixed-position calipers.A combination of Electronic Brake-force Distribution (EBD) and the Super Sport Anti-lock Braking System (ABS) helps to reduce stopping distances and understeer compared to conventional ABS systems. EBD provides precise control of braking pressure between the front and rear wheels based on the vehicle load to improve stability and stopping distances. Super Sport ABS, using input from a lateral-g sensor, can control the braking forces at each rear wheel independently, optimizing the braking ability during hard cornering to help reduce understeer.All Impreza, WRX and WRX
STI models are equipped as standard with the Subaru Advanced Frontal Air bag system and front seat head/chest side impact air bags (SRS). The driver’s side air bag deploys according to the driver’s proximity to the steering wheel, as measured by a sensor on the seat track. In the passenger side front seat, a sensor module detects weight on the passenger seat – first determining if it’s occupied, and if so by a child or adult – to control air bag deployment.For additional information about Subaru of America, Inc. and Subaru vehicles, visit the media website at http://www.media.subaru.com.About Subaru of America, Inc.Subaru of America, Inc. is a wholly owned subsidiary of Fuji Heavy Industries Ltd. of Japan. Headquartered in Cherry Hill, N.J., the company markets and distributes All-Wheel Drive Subaru vehicles, parts and accessories through a network of nearly 600 dealers across the United States. Subaru is the only car company that offers Symmetrical All-Wheel Drive as standard equipment on every vehicle in its product line. Needless to say... I want one.
Re: Subaru 2007 STi Limited (Mavrik)
Posted: Fri Jun 02, 2006 11:36 am
by MrRich
I am one of the few who likes the big wing on STI's. So this one looks naked to me But I am pretty sure it is a hell of a fun to drive.
Re: Subaru 2007 STi Limited (MrRich)
Posted: Fri Jun 02, 2006 12:44 pm
by northvibe
Quote, originally posted by MrRich »I am one of the few who likes the big wing on STI's. So this one looks naked to me But I am pretty sure it is a hell of a fun to drive.+1hmmmm sti i think thats how heaven is spelled
Posted: Fri Jun 02, 2006 1:02 pm
by tangerine
eew, even though I hate the wing on the STI, it looks horrid without one.
Posted: Fri Jun 02, 2006 1:04 pm
by northvibe
the japan STi s204 edition (special jap only) has a nice spoiler....and its fatser!http://images.google.com/imgre...a%3DN
Posted: Fri Jun 02, 2006 1:30 pm
by jwalcik
that's sick. i really dig the sti, but i'm not a fan of the big wing on the normal version.
Re: Subaru 2007 STi Limited (jwalcik)
Posted: Fri Jun 02, 2006 4:43 pm
by Mavrik
I personally have no problems with the big STi wing. Actually I rather like it. However I also like that small spoiler/lip on the trunk. Its not a cop magnet and the car doesn't have that ricer/racer look.
Posted: Sat Jun 03, 2006 2:32 am
by AKLGT
already said this multiple times, i hate that huge (removed) wing on the STI. the lmtd is so much nicer, don't stick out as much for the cops. still, they like to targe anything with a hood scoop. but not as much as a hood scoop and BIG (removed) WING! lol
Posted: Sat Jun 03, 2006 6:49 am
by Atomb
i REALLY like the clean lines on this version. Very nice styling...this comic mirrors my thoughts on the whole wing issue perfectly....btw...i think they look horrible too.
Re: (Atomb)
Posted: Sat Jun 03, 2006 7:16 pm
by ColonelPanic
(removed)! That's great! Subaru needs to invert the limitedness here... Make the in-your-face version the "limited" while giving this one the majority of production. But I guess the majority want to say "what good is driving a WRX if I can't scream out HEY YOU LOSERS, LOOK AT ME, I'VE GOT A WRX!!!???" At least they kept the somewhat-darker-than-Barbie-pink sti logo. lol!
Re: (ColonelPanic)
Posted: Sun Jun 04, 2006 3:20 am
by Mavrik
I got nothing against that STi pink.
Posted: Sun Jun 04, 2006 3:23 am
by AKLGT
the 07 Legacy Spec B is also quite sexy... drool... 6 spd MT with the new SI drive. interesting
Posted: Mon Jun 19, 2006 10:30 pm
by mkaresh
Sounds like the suspension is unchanged. The standard STI suspension provides a very busy ride--and I'm saying this as someone with quite a bit of tolerance in this area. On a highway with prominent expansion joints it'll bounce the whole way down the road--drives me nuts. In this context, I'm not sure the lux trim makes sense.The extra sound insulation might help a bit, though.
Re: Subaru 2007 STi Limited (mkaresh)
Posted: Tue Jun 20, 2006 3:39 am
by Mavrik
Well since I lowered my car, stiff is good. Its no issue for me.
Posted: Wed Jun 21, 2006 3:48 am
by Merzbow
Not bad....the taillights are repulsive and I don't like it without a spoiler either but it doesn't look too bad
Re: Subaru 2007 STi Limited (Merzbow)
Posted: Wed Jun 21, 2006 4:01 am
by Mavrik
You can swap out those tailights for with 2004-2005 model tail lights. My friend Travis has 06 tails on his 05 STi. Guess he liked them better.
Posted: Wed Jun 21, 2006 7:21 am
by AKLGT
i like those taillights.
