My floor is soaked on the passenger side
Posted: Fri May 19, 2006 5:56 am
by Dans_03Vibe
i see drops of water coming out from the bottom of the dashbored
Re: My floor is soaked on the passanger side (Dans_03Vibe)
Posted: Fri May 19, 2006 5:57 am
by Mrizzle05
Water bottle in the glove box??? The only thing i can think of is maybe the A/C is leaking and the condensation in right in that area. but just an opinion. not 100%
Posted: Fri May 19, 2006 6:02 am
by northvibe
does the heater core leak water if it breaks?
Posted: Fri May 19, 2006 6:27 am
by millster
Maybe this will help.Seems to be a rather common problem.
http://forums.genvibe.com/zerothread?id=10977
Posted: Fri May 19, 2006 6:51 am
by northvibe
ohhh i bet thats it! i should check mine just in case....
Posted: Fri May 19, 2006 9:36 am
by scherry2
millster is probably right.haven't heard of this on fro a while.
Posted: Sat May 20, 2006 7:09 am
by Dans_03Vibe
Fixed it!
Re: (Dans_03Vibe)
Posted: Sat May 20, 2006 7:16 am
Quote, originally posted by Dans_03Vibe »Fixed it!So, was it the AC drain hose had become disconnected as genvibe hero millster had suggested, or was it some other problem?
Posted: Sat May 20, 2006 7:59 am
by Dans_03Vibe
i look down there and didnt even see the hose so i diged for it and found it and just put it on and ziped tied it down
