would i lose any power.. "Dual" exhaust...
Posted: Mon May 15, 2006 1:33 pm
by P-Fernandez
i need your $0.02 ... on this idea..dont wanna spend more than 200
Posted: Mon May 15, 2006 1:42 pm
by AKLGT
you'll probably lose a little power. i don't know for sure, but my cousin was explaining that to me when i was looking to do the same on my vibe gt while ago. i'm sure one of the more "in tune" experts will advice more.
Re: would i lose any power.. Dual" exhaust... (P-Fernandez)
Posted: Mon May 15, 2006 10:04 pm
by Raven
Magnaflow makes a muffler that's single inlet and dual outlet (one on each end), made for camaros and firebirds with dual exhaust. The muffler mounts sideways just like the Vibe. You could use the stock pipe on the driver's side and get one made for the passenger side. I was going to do it on my '04. I think you would gain a few ponies with less backpressure, just like a Magnaflow cat-back system.http://www.magnaflow.com/02pro...d=637h ... ...d=635Or in satin finishhttp://www.magnaflow.com/02pro...d=477
Posted: Tue May 16, 2006 4:47 am
by P-Fernandez
on the 2nd one... which is the inlet , and which are outlets...$ 216 the muffler !!better find agood ebay dealwhch is better 1st or 2nd??
Re: (P-Fernandez)
Posted: Tue May 16, 2006 9:54 am
by Raven
The bottom 2 which are 2.25" are the outlets, they messed up their picture. You can get them much cheaper from any place that sells Magnaflow. The manufacturers always put a high price on their site so as to not undercut any of their dealers prices and to save themselves the trouble of shipping stuff out in small quantities. I would go with the second one, it looks simpler and would be easy to hook up.
Posted: Tue May 16, 2006 11:00 am
by P-Fernandez
I think for $86 il just go with the dynomax, and leave it as single... thanks tho
Posted: Thu May 18, 2006 2:42 am
by ToolGuy
No loss of power if you go two... The exhaust gases will have two paths to exist verses only one. However doing just an muffler you will probably not see even a gain, just a nice sound tone. 1 or 2, you should be happy with either.
Re: would i lose any power.. Dual" exhaust... (Sunny)
Posted: Mon May 22, 2006 7:50 am
by GM Enthusiast
Dynomax makes an Ultraflo single in, dual out muffler also. I used one years back to make an exhaust for a Cavalier... with the added space under the back of the Vibe it would be even easier to do then it was on the Cavalier.See attached image.
Re: would i lose any power.. Dual" exhaust... (GM Enthusiast)
Posted: Mon May 22, 2006 8:56 am
by Raven
Nice clean looking set-up.
Posted: Mon May 22, 2006 4:30 pm
by NascarXprt
thatll look nice and sound great on a vibe. quick some one do it and post pics and sound clips of it.
Posted: Tue May 23, 2006 1:07 am
by P-Fernandez
Hey well m REALLY thinking about going that on the vibe since i found the 3rd link (Sunny) for $91 at Summit Racing.. so i might just do that...BUT - - - - - would it sound good on a vibe? Camaros are V8's.....Vibe is a 4i still want good sound ( deep prefebly )---How much do you think i'll end up spending on my setup ... without including muffler...i also want 2 4" rolled tips. ~ $20 each
Re: (P-Fernandez)
Posted: Tue May 23, 2006 1:16 am
by Mrizzle05
depending on what you want plus labor your looking at close to 300 bucks bro. its only $380.. which is a lot but a lil more then what you would spend on a set upThats how i was... then i just sucked it up and got a magnaflow. it sounds soo good and i feel more pep in the ol 4 banger.Its pretty easy to install too... just dont cut at the wrong part like i did. (long day & bad direction reading!)
Re: would i lose any power.. "Dual" exhaust... (P-Fernandez)
Posted: Tue May 23, 2006 1:25 am
by freestyle
I put duel exhaust on vibe and i don't see any power lost and to keep it cheep i just had muffler shop custom make me a duel set up. If you want to see how it looks go to cardomain.com and look at mine.
Posted: Tue May 23, 2006 1:40 am
by P-Fernandez
U have a sweet looking vibe.. I ove the STi Scoop & Cobalt SS Spoiler ! Freestyle ... how much did u pay for labor?What all did you get done... Muffler to Tip, Or everything?
Posted: Thu Jun 22, 2006 2:13 am
by cknight725
The torque loss would be pretty minimal since its not a true dual exhaust. If you really want to keep that torque make sure you stay with the same tube size to the muffler, then drop the tube size a quarter-to half inch on the exit from the muffler. That will keep the torque on tap for you and give the dual exhaust look.
