Heavy duty front end links.
Posted: Tue May 09, 2006 9:38 pm
by limE
SILVERAWD26 is now running this he has a lathe.
Re: Heavy duty front end links. (limE)
Posted: Wed May 10, 2006 3:52 pm
by kerrykerrykerry
when do you expect to have final production versions ready?
Re: Heavy duty front end links. (kerrykerrykerry)
Posted: Thu May 11, 2006 2:19 am
by limE
Posted: Thu May 11, 2006 5:57 am
by kerrykerrykerry
what are the other benefits these provide, besides creating clearance to avoid the parts rubbing? Do they give a tighter feel to the steering wheel, better response over bumps, etc, etc? im interested in these, i just dont want to read through the Plethora of pages over at matrixowners.
Posted: Thu May 11, 2006 12:47 pm
by limE
Posted: Thu May 11, 2006 2:02 pm
by kerrykerrykerry
right now, im running S-techs with hotchkis sways on the way, possibly TEIN basics if i decide not to buy another car. They will work fine with just s-techs and hotchkis sways, correct? If so, im sold.
Posted: Thu May 11, 2006 3:25 pm
by northvibe
do you have to have the tein coil overs and hotchkis sway bar or could i still have the stock suspension?
Re: (northvibe)
Posted: Thu May 11, 2006 8:33 pm
by limE
With the stock suspension i would leave the stock end links in if they are still good.
Re: (silverawd26)
Posted: Thu May 11, 2006 11:42 pm
by limE
you probably can, but do you have a lathe to tap the threads left and right. Also you need to make shure the rods are within 10 thou of one another. Can you heat treat the rods because the finished product will be heat treated. The cost is as much in the accuracy as in the material.Also you have to make shure there is not much run out due to the fact that the spherical rod ends need to be 90 to one another.
Posted: Fri May 12, 2006 3:52 am
by Shadow-Vibe
I ordered a set through Hotchkis after I ordered my sways. Not sure what I paid for them now. But I do like them 100% better than the stocks.
Re: (silverawd26)
Posted: Fri May 12, 2006 8:04 am
by limE
not everyone is as lucky as you. Maybe you can help all the genvibers out. Thanks for yuor time.good luck guys
Re: (limE)
Posted: Sat May 13, 2006 3:55 pm
by limE
What happened to everyone ???? I need to order a set of those hardware store end links SILVERAWD26 is selling
Posted: Mon May 22, 2006 11:46 pm
by cknight725
Color me stupid ... Why?
Re: (limE)
Posted: Tue May 23, 2006 10:25 pm
by Shadow-Vibe
If you can get me the thread size and eye dimension, I can order these through my work to make your own.
